Hello Fellow Forum-persons! Does any one out there in Forumland know of a safe site to download AutoCAD linetypes from? - Thanks, Dave
Just create your own then you won't have to worry about catching a virus.
Thanks ReMark, I suppose that is the best approach and I will have to look into doing that.
Just some fairly standard ones like "fenceline ----x----x----", ---gas---gas---, etc.
I didn't notice the links that you sent; I'll check 'em out - thanks ReMark!
Hi ReMark - I have done some linetype file downloading and was hoping that you could give me instruction on how to insert them into my AutoCAD 2008 program.
Thanks,
Dave
I would recommend that you do not add the new linetypes to your acad.lin file. I would create a folder called MyLinetypes and put the .LIN file(s) in it and make sure the path to the folder is added via Options > Files > Support File Search Path.
Thanks Blackfish, I'll give it a try!
Thanks ReMark, I'll give it a try!
