MarkX Posted October 30, 2008 Posted October 30, 2008 I am not a programer but my boss wants me to do this so i am going to do my best to get it done. I need to create a userform that will allow for ten or so different selection rules for a drawing. These rules will turn layers in the drawing on and off depending on parameters in the selection rule. I have found a few things that I think might be helpful but I am unsure of how to change them or what I need to do to make them work for me. This is the code that I found for the layer selestion/fliltering. Option Explicit Public Function LayerSelection(strLayerName As String, strSSName) _ As AcadSelectionSet Dim ssObjects As AcadSelectionSet Dim intCode(0) As Integer Dim varData(0) As Variant Dim objCheck As AcadSelectionSet 'declare variables intCode(0) = 8 'set variable for the dxf code for layer varData(0) = strLayerName 'set variable for the layer name Set ssObjects = ThisDrawing.SelectionSets.Add(strSSName) 'create a selection eset ssObjects.Select acSelectionSetAll, , , intCode, varData 'select all entities on the specified layer Set LayerSelection = ssObjects 'create a reference to the selection End Function This is the code that I found for the user form. Private Sub UserForm_Click() Me.Height = Int(Rnd * 500) Me.Width = Int(Rnd * 750) End Sub Private Sub UserForm_Initialize() Me.Caption = "Userform Events" Me.BackColor = RGB(10, 25, 100) End Sub Private Sub UserForm_QueryClose(Cancel As Integer, CloseMode As Integer) msg = "Now Unloading " & Me.Caption MsgBox prompt:=msg, Title:="QueryClose Event" End Sub Private Sub UserForm_Resize() msg = "Width: " & Me.Width & Chr(10) & "Height : " & Me.Height MsgBox prompt:=msg, Title:="Resizing Event" End Sub Private Sub UserForm_Terminate() msg = "Now Unloading " & Me.Caption MsgBox prompt:=msg, Title:="Terminate Event" End Sub Like I said I have very little experience doing any programing so any help that I could get with this problem would be great. Quote
papagyi Posted October 30, 2008 Posted October 30, 2008 This place will help you..http://www.cadtutor.net/forum/forumdisplay.php?f=21 Quote
