I am not a programer but my boss wants me to do this so i am going to do my best to get it done. I need to create a userform that will allow for ten or so different selection rules for a drawing. These rules will turn layers in the drawing on and off depending on parameters in the selection rule. I have found a few things that I think might be helpful but I am unsure of how to change them or what I need to do to make them work for me. I know that I need to make a userform and then give it code to do this but I just am unsure where to even start. Any help or ideas of where to start would be great.
List out your 10 items and how you want it to work, then we can code it with you
The ten items are going to be custom selection options that my boss is going to define for me. He wants them to be selectable from a drop down menu or I think it is called a Combobox in VBA. I need help setting up the userform to get combobox setup so i will be able to put the codes in that he wants. I am not even sure how to setup a combobox so that it can have ten items to select from. I should be getting the specs for the code later today and will post them as soon as i can. Thank you for all your help. This is part of the old version of the code that i am making thin new macro for.
Option Explicit
' *** Public Declarations **** '
Public strModelNum As String
Public strSalesOrdNum As String
Public objLayer As AcadLayer
Private Sub cbo9_Change()
 On Error GoTo Err_Control
 If cbo9.Value = "U = Pueblo" Then
   dig9.Caption = "U"
   dig9.BackColor = &HFF00&
   stopgo9.BackColor = &HFF00&
 ElseIf cbo9.Value = "E = Charmes" Then
   dig9.Caption = "E"
 ElseIf cbo9.Value = "C = China" Then
   dig9.Caption = "C"
 ElseIf cbo9.Value = "" Then
   stopgo9.BackColor = &HFF&
   dig9.BackColor = &HFF&
 End If
   stopgo13.BackColor = &HFF&
   stopgo16.BackColor = &HFF&
   stopgo26.BackColor = &HFF&
   stopgo27.BackColor = &HFF&
   stopgo28.BackColor = &HFF&
   dig13.BackColor = &HFF&
   dig16.BackColor = &HFF&
   dig26.BackColor = &HFF&
   dig27.BackColor = &HFF&
   dig28.BackColor = &HFF&
   cbo13.Clear
   cbo16.Clear
   cbo26.Clear
   cbo27.Clear
   cbo28.Clear
   dig13.Caption = ""
   dig16.Caption = ""
   dig26.Caption = ""
   dig27.Caption = ""
   dig28.Caption = ""
   cbo16.Enabled = False
   cbo26.Enabled = False
   cbo27.Enabled = False
   cbo28.Enabled = False
   cbo13.AddItem "U = C/UL Listing"
   cbo13.AddItem "C = CE Listing"
   cbo13.Enabled = True
   cbo13.SetFocus
Exit_Here:
 Exit Sub
Err_Control:
 Debug.Print Err.Number
 MsgBox Err.Description
End Sub
From the information in the zip file i need to make a userform that will allow for a menu or two that has the Region, Unit conf, Compressor power, Fans, Pump package, and for each of the items below the tilte to match the layers with that description and when selected to turn off all the other layers.
SCHEMATIC INFORMATION.zip
