NoelStalker Posted October 30, 2008 Posted October 30, 2008 Hello everyone, I would like to create an array for different zoom scales. Currently, here is the code I have typed manually in nominal scales by 5 (see below). However, I would like to be able to create a keyboard command for any zoom scale but that would take forever to type out. I don't really understand the language that is being used for lisp files but I know that you can create arrays in other languages to do such a thing as this (i.e. web design). (defun c:z1 () (command "zoom" "s" "1/1xp") ) (defun c:z5 () (command "zoom" "s" "1/5xp") ) (defun c:z10 () (command "zoom" "s" "1/10xp") ) (defun c:z15 () (command "zoom" "s" "1/15xp") ) (defun c:z20 () (command "zoom" "s" "1/20xp") ) (defun c:z25 () (command "zoom" "s" "1/25xp") ) (defun c:z30 () (command "zoom" "s" "1/30xp") ) (defun c:z35 () (command "zoom" "s" "1/35xp") ) Quote
Lee Mac Posted October 30, 2008 Posted October 30, 2008 Only typed this one up quickly, but may be of some use: (defun c:zs (/ sc sc1) (setvar "cmdecho" 0) (setq sc (getint "Specify Scale Factor: 1/")) (setq sc1 (strcat "1/" (rtos sc) "xp")) (command "_zoom" "S" sc1 ) ; end zoom (setvar "cmdecho" 1) (prompt "\nZoom Complete. ") (princ) ) Quote
rkmcswain Posted October 30, 2008 Posted October 30, 2008 If you want the actual function names like Z1, Z2, Z3, etc., then give this a shot. This will create functions Z1 through Z100 (setq i 1) (while (<= i 100) (eval (read (strcat "(defun c:Z" (itoa i) (chr 40)(chr 41) "(command \"._zoom\" \"1" (chr 47) (itoa i) "XP\"))"))) (setq i (1+ i)) ) Quote
NoelStalker Posted October 30, 2008 Author Posted October 30, 2008 Thanks LeeMac, that is exactly what I need and now I know how to make an array. rkmcswain, that is a cool, creative way of doing it without the need for an array. It wouldn't work though, when I put in a number, it asked for xp and when I put in xp it said that it expected an integer value. Thanks for both of your help and have a great day! Sincerely, Noel Quote
rkmcswain Posted October 30, 2008 Posted October 30, 2008 rkmcswain, that is a cool, creative way of doing it without the need for an array. It wouldn't work though, when I put in a number, it asked for xp and when I put in xp it said that it expected an integer value. Hmmm... Works fine here... Command: [b]4[/b] ._zoom Specify corner of window, enter a scale factor (nX or nXP), or [All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: [b]1/4XP[/b] Command: Command: [b]16[/b] ._zoom Specify corner of window, enter a scale factor (nX or nXP), or [All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: [b]1/16XP[/b] Command: Command: [b]88[/b] ._zoom Specify corner of window, enter a scale factor (nX or nXP), or [All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: [b]1/88XP[/b] Command: Quote
NoelStalker Posted November 5, 2008 Author Posted November 5, 2008 ah, rkmcswain, now I see how your program works. I thought that I had to type z2, z8, z12, etc. but you make the number the command. Thanks for your input. Quote
