Recieved O.S. Map and find replica of model space drawing on Layer 1 and which can't be deleted. Can't set up other layout tabs either without same drawing appearing. How do I get a clear layout in paper space?
Layout 1 (assuming it's the only layout) cannot be deleted (actually you can delete it, but another Layout 1 is created).
The reason you are seeing MS entities when a new layout is created is because "Create viewport in new layouts" is checked ON in Options>Display tab. Uncheck this and create a new layout.
Thanks, R.K. Problem solved. Why do I always miss the obvious? Guess I'm well named! Thanks again:)
