myself Posted June 12, 2012 Posted June 12, 2012 I'm trying to put some hangers along a line of pipes, my question is, simple as this. How can i use the hangers to agroup pipes, when i use the hanger command, the hanger immediately gets attached to one pipe, when what i wanted to have an hanger supporting a group of parallel pipes.... Does anyone here had the same problem? Quote
tzframpton Posted June 19, 2012 Posted June 19, 2012 In this scenario I always just used standard 3D Solids to place hangers - instead of using the Hanger Tools. The only way I can see this working out is if you modified the hanger to be really long on one side to accommodate the other parallel pipes. Quote
