cadamrao Posted June 14, 2012 Posted June 14, 2012 hi i need select similar LISP for ((horizontal line,polyline or vertical line,polyline).plz find example attachment. I appreciate quick response venki Quote
Tharwat Posted June 14, 2012 Posted June 14, 2012 Here is my version to select Vertical or horizontal Lines / polylines according to user' s choose . (defun c:Test (/ sel ss go) (vl-load-com) ;;;; ******* Tharwat 14. June . 2012 ******* ;;;;;; ;;;; This peice of code to select Horizontal or Vertical ;;;;; ;;;; lines or Polylines according to user's choose ;;;;; (defun Catch (ang1 ang2 ss) ((lambda (l / i n sn e x p1 p2) (while (setq sn (ssname ss (setq l (1+ l)))) (setq e (entget sn)) (if (wcmatch (cdr (assoc 0 (entget sn))) "*POLYLINE") (progn (setq i 0 n 0 ) (repeat (setq x (fix (vlax-curve-getendparam sn))) (if (or (equal (angle (setq p1 (vlax-curve-getpointatparam sn i)) (setq p2 (vlax-curve-getpointatparam sn (setq i (1+ i)) ) ) ) ang1 ) (equal (angle p1 p2) ang2) ) (setq n (1+ n)) ) ) (if (eq n x) (ssadd sn sel) ) ) (if (or (eq (angle (cdr (assoc 10 e)) (cdr (assoc 11 e))) ang1) (eq (angle (cdr (assoc 10 e)) (cdr (assoc 11 e))) ang2) ) (ssadd sn sel) ) ) ) ) -1 ) (princ) ) (if (and (setq sel (ssadd)) (progn (initget "Horizontal Vertical") (setq go (getkword "\n Choose one [Horizonta/Vertical] :")) ) (setq ss (ssget "_:L" '((0 . "*POLYLINE,LINE")))) ) (if (eq go "Horizontal") (Catch 0.0 pi ss) (Catch (/ pi 2.) (* pi 1.5) ss) ) ) (if (> (sslength sel) 0) (sssetfirst nil sel) ) (princ) ) Quote
BlackBox Posted June 14, 2012 Posted June 14, 2012 Perhaps I am missing something... Given the sample screenshot posted above, why will SELECTSIMILAR Command not work? Quote
Tharwat Posted June 14, 2012 Posted June 14, 2012 Perhaps I am missing something... Given the sample screenshot posted above, why will SELECTSIMILAR Command not work? Firstly the OP using cad 2006 which the new command is not available before cad 2012 , and the second issue is that the Angle option is not available into that new command call . Quote
BlackBox Posted June 14, 2012 Posted June 14, 2012 Firstly the OP using cad 2006 which the new command is not available before cad 2012 , and the second issue is that the Angle option is not available into that new command call . Tharwat, the SELECTSIMILAR Command has been around since +/-2006; I used it with Land Desktop (LDD) 2006... Admittedly, LDD had functionality that Vanilla does not. Secondly, you're presuming that the lack of a vertical, or horizontal selection option is a flaw in the design of the command, when in fact it serves a greater purpose... To make it incumbent upon the user to adhere to 'good' drafting practices, in which case this selection option is not necessary (IMHO)... Instead, one can rely upon other LAY* Commands to accomplish their goal. Quote
cadamrao Posted June 18, 2012 Author Posted June 18, 2012 Thanks a LOT spending time for me;great works venki Here is my version to select Vertical or horizontal Lines / polylines according to user' s choose . (defun c:Test (/ sel ss go) (vl-load-com) ;;;; ******* Tharwat 14. June . 2012 ******* ;;;;;; ;;;; This peice of code to select Horizontal or Vertical ;;;;; ;;;; lines or Polylines according to user's choose ;;;;; (defun Catch (ang1 ang2 ss) ((lambda (l / i n sn e x p1 p2) (while (setq sn (ssname ss (setq l (1+ l)))) (setq e (entget sn)) (if (wcmatch (cdr (assoc 0 (entget sn))) "*POLYLINE") (progn (setq i 0 n 0 ) (repeat (setq x (fix (vlax-curve-getendparam sn))) (if (or (equal (angle (setq p1 (vlax-curve-getpointatparam sn i)) (setq p2 (vlax-curve-getpointatparam sn (setq i (1+ i)) ) ) ) ang1 ) (equal (angle p1 p2) ang2) ) (setq n (1+ n)) ) ) (if (eq n x) (ssadd sn sel) ) ) (if (or (eq (angle (cdr (assoc 10 e)) (cdr (assoc 11 e))) ang1) (eq (angle (cdr (assoc 10 e)) (cdr (assoc 11 e))) ang2) ) (ssadd sn sel) ) ) ) ) -1 ) (princ) ) (if (and (setq sel (ssadd)) (progn (initget "Horizontal Vertical") (setq go (getkword "\n Choose one [Horizonta/Vertical] :")) ) (setq ss (ssget "_:L" '((0 . "*POLYLINE,LINE")))) ) (if (eq go "Horizontal") (Catch 0.0 pi ss) (Catch (/ pi 2.) (* pi 1.5) ss) ) ) (if (> (sslength sel) 0) (sssetfirst nil sel) ) (princ) ) Quote
Tharwat Posted June 18, 2012 Posted June 18, 2012 Thanks a LOT spending time for me;great works venki Happy to hear that . You're welcome . Quote
