MisterJingles Posted June 14, 2012 Posted June 14, 2012 Hi all I drew a building which due to site constraints now has to be mirrored in its entirety, now my windows, aircons etc are all mirrored incorrectly with the text "facing down". I know how MIRRTEXT works, is there a command which would allow me to do the same thing with a block which contains text? IE The block mirrors but the text remains "facing up"? Thanks Quote
MisterJingles Posted June 14, 2012 Author Posted June 14, 2012 I've tried it with it set both ways (MIRRTEXT = 0 and MIRRTEXT = 1) but it still mirrors facing down. Quote
nestly Posted June 14, 2012 Posted June 14, 2012 Text and MText objects within blocks get mirrored when a block is mirrored. If you need the text to remain "right-reading" I believe it has to be an Attribute. Quote
dbroada Posted June 14, 2012 Posted June 14, 2012 Text and MText objects within blocks get mirrored when a block is mirrored. If you need the text to remain "right-reading" I believe it has to be an Attribute.It is possible that that is what I have. Quote
SLW210 Posted June 14, 2012 Posted June 14, 2012 From AutoCAD help--- MIRRTEXT affects text that is created with the TEXT, ATTDEF, or MTEXT commands; attribute definitions; and variable attributes. Text and constant attributes that are part of an inserted block are reversed when the block is mirrored regardless of the MIRRTEXT setting. Quote
MisterJingles Posted June 14, 2012 Author Posted June 14, 2012 From AutoCAD help--- Pity. Thanks Quote
dbroada Posted June 14, 2012 Posted June 14, 2012 from a quick test, text within a block is mirrored irrespective of MIRRTEXT setting while attibutes mirror or remain right reading depending on the setting. I don't use constant attributes. Quote
