Costinbos77 Posted July 11, 2014 Posted July 11, 2014 I am glad to hear that you find this program useful. But I do not understand what you want. See attachment. Maybe you have not downloaded the latest version. Area.dwg Quote
Stephen316 Posted July 14, 2014 Posted July 14, 2014 Dear Costinbos77, I have downloaded the latest code and it is working fine, but there are few issues, Actually my drawing is in 1:100 scale and all dimensions are in mm. The issues i face now are as below, 1. the default text height is 0.2 which is too small for my scale. 2. The areas that the code gives are in mm2 so i need to convert it to m2. 3. Same like point 2 the poly line lengths are in mm, though the codes prints them as metre. I am attaching the drawing that i have been working on for clarity. It has got only polylines i have not included architectural background. Also i have manually changed the text height to 200 in the attached drawing. Can we modify the code to input scale of drawing and text height, if it will be too complicated then its fine, we can keep this as such. Thanks in advance, Regards Stephen Drawing.dwg Quote
