; error: Exception occurred: 0xC0000005 (Access Violation)
Hello I would like to know if anyone ever saw this error .
; warning: unwind skipped on unknown exception
and If they know how to fix it.. because when I run my code it does that.
Thank for the help !
Cheers & Beers
It must be a secret code.
How about you provide us with a wee bit more information OK there Frank? Thanks.
Do you know the line of code that forced the error?
Yes I do, Thing is when i run this part of code alone in another file.lsp it runs perfect. so ill post both codes and this goes with the tread Visual Lisp & Look up. but since it was a seperate question from the code i didnt put it in it.
Now here's the full code :
;¦¦¦               CE PROGRAM EST CONÇU POUR DESSINNER UN PLAN               ¦¦¦;
;¦¦¦                     DE GRUE À TOUR LINDEN COMANSA                       ¦¦¦;
;¦¦¦ _______________________________________________________________________ ¦¦¦;
;¦¦¦                   AUTEUR : CadFrank, Copyright ® 2012                   ¦¦¦;
;¦¦¦              Ce sous-program défini le rayon de la fleche               ¦¦¦;
;¦¦¦                               Vue en plan                               ¦¦¦;
(defun Fleche (/ pt1 p-itm P-fleche p-dbp p-bp p-ListeAdmis)
 (setq pt1 (getpoint "\n Selection le point d'implantation de la grue : "))
      (setq P-fleche
             (vla-insertblock
               (vla-get-modelspace
                 (vla-get-activedocument
                   (vlax-get-acad-object)))
                     (vlax-3d-point pt1) "LC FLECHE" 1 1 1 0)
          );setq fleche
     (setq p-dbp (vla-getdynamicblockproperties P-fleche))
     (setq p-dbp (vlax-variant-value p-dbp))
     (setq p-dbp (vlax-safearray->list p-dbp))
     (setq p-bp (car p-dbp))
     (setq p-ListeAdmis (vlax-safearray->list (vlax-variant-value (vla-get-AllowedValues p-bp))))
     (setq p-ListeAdmis (mapcar 'vlax-variant-value p-ListeAdmis))
     (vla-put-value p-bp (strcat R-Fleche " m"))
);defun "fin du sous-program FLECHE"
;¦¦¦                                21 LC 170                                ¦¦¦;
(defun Fleche170 (/ f-itm B-fleche f-dbp f-bp f-ListeAdmis)
   (foreach
      f-itm '(("LC CHARGE 170" . (0 70000 0))
              ("LC C-P 170" . (8000 70000 0))
              ("LC B-T 170" . (20000 70000 0))
          ("LC FLECHE 170" . (0 0 0))
      (setq B-fleche
             (vla-insertblock
               (vla-get-modelspace
                     (vlax-3d-point (cdr f-itm)) (car f-itm) 1 1 1 0)
          );setq fleche
     (setq f-dbp (vla-getdynamicblockproperties B-fleche))
     (setq f-dbp (vlax-variant-value f-dbp))
     (setq f-dbp (vlax-safearray->list f-dbp))
     (setq f-bp (car f-dbp))
     (setq f-ListeAdmis (vlax-safearray->list (vlax-variant-value (vla-get-AllowedValues f-bp))))
     (setq f-ListeAdmis (mapcar 'vlax-variant-value f-ListeAdmis))
     (vla-put-value f-bp (strcat R-Fleche " m"))
   );foreach
); defun "fin du sous-program Fleche"
;¦¦¦                                21 LC 210                                ¦¦¦;
(defun Fleche210 (/ f-itm B-fleche f-dbp f-bp f-ListeAdmis)
   (foreach
      f-itm '(("LC CHARGE 210" . (0 70000 0))
              ("LC C-P 210" . (8000 70000 0))
              ("LC B-T 210" . (20000 70000 0))
          ("LC FLECHE 210" . (0 0 0))
      (setq B-fleche
             (vla-insertblock
               (vla-get-modelspace
          );setq fleche
   );foreach
;¦¦¦                                21 LC 290                                ¦¦¦;
(defun Fleche290 (/ f-itm B-fleche f-dbp f-bp f-ListeAdmis)
   (foreach
      f-itm '(("LC CHARGE 290" . (0 70000 0))
              ("LC C-P 290" . (8000 70000 0))
              ("LC B-T 290" . (20000 70000 0))
          ("LC FLECHE 290" . (0 0 0))
      (setq B-fleche
             (vla-insertblock
               (vla-get-modelspace
          );setq fleche
   );foreach
;¦¦¦                                21 LC 550                                ¦¦¦;
(defun Fleche550 (/ f-itm B-fleche f-dbp f-bp f-ListeAdmis)
   (foreach
      f-itm '(("LC CHARGE 550" . (0 70000 0))
              ("LC C-P 550" . (8000 70000 0))
              ("LC B-T 550" . (20000 70000 0))
          ("LC FLECHE 550" . (0 0 0))
      (setq B-fleche
             (vla-insertblock
               (vla-get-modelspace
          );setq fleche
   );foreach
;¦¦¦                      Se sous-programme sélectionne la                   ¦¦¦;
;¦¦¦                             Séquence de Montage                         ¦¦¦;
(defun Sequence_Montage (/ pt1 blk)
 (if (= typ-grue "170")(setq pt1 '((40000 70000 0) . "LC S-M 170")))
 (if (= typ-grue "210")(setq pt1 '((40000 70000 0) . "LC S-M 210")))
 (if (= typ-grue "290")(setq pt1 '((40000 70000 0) . "LC S-M 290")))
 (if (= typ-grue "550")(setq pt1 '((40000 70000 0) . "LC S-M 550")))
 (if (setq blk   (vla-insertblock
               (vla-get-modelspace
                     (vlax-3d-point (car pt1)) (cdr pt1) 1 1 1 0)
 (progn (setq  f-dbp (car (vlax-invoke blk 'GetDynamicBlockProperties)))
        (vla-put-value  f-dbp (strcat R-fleche " m"))
         (vla-put-textstring (car (vlax-invoke blk 'GetAttributes)) N-tour)
);fin
;¦¦¦               Ce sous-programme défini le nombre de tour                ¦¦¦;
(defun TourS25 (/ B-tour t-dbp t-bp)
 (foreach
    t-itm '(("LC TOUR S25" . (0 0 0))
           (setq B-tour
            (vla-insertblock
               (vla-get-modelspace
                     (vlax-3d-point (cdr t-itm)) (car t-itm) 1 1 1 0)
           );setq tour
 (setq t-dbp (vla-getdynamicblockproperties B-tour))
 (setq t-dbp (vlax-variant-value t-dbp))
 (setq t-dbp (vlax-safearray->list t-dbp))
 (setq t-bp (caddr t-dbp))
 (setq t-ListeAdmis (vlax-safearray->list (vlax-variant-value (vla-get-AllowedValues t-bp))))
 (setq t-ListeAdmis (mapcar 'vlax-variant-value t-ListeAdmis))
 (vla-put-value t-bp N-tour)
 );foreach
);defun "fin du sous-programme Tour"
(defun TourD33 (/ B-tour t-dbp t-bp)
 (foreach
    t-itm '(("LC TOUR D33" . (0 0 0))
           (setq B-tour
            (vla-insertblock
               (vla-get-modelspace
           );setq tour
 (setq t-bp (car t-dbp))
 );foreach
;¦¦¦                       Se sous-programme sélectionne                     ¦¦¦;
;¦¦¦                              le tableau des                             ¦¦¦;
;¦¦¦                          Dispositifs de Sécurité                        ¦¦¦;
(Defun Dispositif (/ pt2 D-S-blk D-S-dbp V-AGS)
 (setq pt2 '((40000 55000 0) . "LC D-S TEXTE"))
 (if (= S-AGS "Oui")(setq V-AGS "AVEC AGS"))
 (if (= S-AGS "Non")(setq V-AGS "SANS AGS"))
 (if (setq D-S-blk (vla-insertblock
               (vla-get-modelspace
                     (vlax-3d-point (car pt2)) (cdr pt2) 1 1 1 0)
   (progn (setq  D-S-dbp (car (vlax-invoke D-S-blk 'GetDynamicBlockProperties)))
          (vla-put-value  D-S-dbp V-AGS )
); fin
;¦¦¦                            Se sous-programme                            ¦¦¦;
;¦¦¦                       Applique les Notes du courant                     ¦¦¦;
;¦¦¦                               Éléctrique                                ¦¦¦;
(defun CourantElect (/ pt4 N-E-dbp C-E N-E-blk)
 (setq pt4 '((40000 80000 0) . "LC TEXTE ELECT"))
  (vla-insertblock
               (vla-get-modelspace
                     (vlax-3d-point (car pt4)) (cdr pt4) 1 1 1 0)
  (progn (setq  N-E-dbp (car (vlax-invoke N-E-blk 'GetDynamicBlockProperties)))
         (vla-put-value  N-E-dbp C-E )
);fin du sous-programme CourantElect
;¦¦¦                           Début du Programme                            ¦¦¦;
(defun c:grue (/ typ-Grue R-fleche N-tour)
 (vl-load-com)
 (initget 1 "170 210 290 550")
 (setq typ-Grue (getkword "\n Donner le type de grue [170/210/290/550] : "))
   (cond ((= typ-Grue "170")
             (initget 1 "60 54 50 44 40 34 30")
             (setq R-Fleche (getkword "\n Donner le rayon de la flèche [60/54/50/44/40/34/30] : ")))
   (cond ((= typ-Grue "210")
             (initget 1 "64 60 54 50 44 40 34 30")
         (setq R-Fleche (getkword "\n Donner le rayon de la flèche [64m/60m/54m/50m/44/40/34/30] : ")))
   (cond ((= typ-Grue "290")
             (initget 1 "74 70 64 60 54 50 44 40")
         (setq R-Fleche (getkword "\n Donner le rayon de la flèche [74/70/64/60/54/50/44/40] : ")))
   (cond ((= typ-Grue "550")
             (initget 1 "80 74 70 64 60 50 40")
             (setq R-Fleche (getkword "\n Donner le rayon de la flèche [80/74/70/64/60/50/40] : ")))
 (initget 1 "4 5 6 7 8 9 10 11")
 (setq N-tour (getkword "\n Donner le nombre de tour [4/5/6/7/8/9/10/11] : "))
 (initget 1 "Oui,O Non,N")
 (Setq S-AGS (getkword "\n La grue a-t-elle besoin d'un système Anticolision? [O/N]"))
 (initget 1 "5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0")
 (setq D-Base (getkword "\n Donner la Dimension de la base : [5.0/5.5/6.0/6.5/7.0/7.5/8.0/8.5/9.0/9.5/10.0] : "))
 (initget 1 "1.50 1.55 1.60 1.65 1.70 1.75 1.80 1.85 1.90 1.95 2.00")
 (setq H-Base (getkword "\n Donner le hauteur de la base : [1.50/1.55/1.60/1.65/1.70/1.75/1.80/1.85/1.90/1.95/2.00] : "))
 (Fleche)
 (if (= typ-Grue "170")(Fleche210))
 (if (= typ-Grue "210")(Fleche210))
 (if (= typ-Grue "290")(Fleche290))
 (if (= typ-Grue "550")(Fleche550))
 (Sequence_Montage)
 (if (= typ-Grue "170")(TourS25))
 (if (= typ-Grue "210")(TourS25))
 (if (= typ-Grue "290")(TourS25))
 (if (= typ-Grue "550")(TourD33))
 (Dispositif)
 (CourantElect)
 (BaseBeton)
);defun c
;¦¦¦                        Détermine les dimension de                       ¦¦¦;
;¦¦¦                            la base de béton                             ¦¦¦;
(defun BaseBeton (/ pt5 B-B-blk B-B-dbp B-B-bp B-B-ListeAdmis)
 (foreach
    pt5 '(("LC BASES" . (60000 60000 0))
 (setq B-B-blk (vla-insertblock
               (vla-get-modelspace
                     (vlax-3d-point (cdr pt5)) (car pt5) 1 1 1 0)
 (setq B-B-dbp (vla-getdynamicblockproperties B-B-blk))
 (setq B-B-dbp (vlax-variant-value B-B-dbp))
 (setq B-B-dbp (vlax-safearray->list B-B-dbp))
 (setq B-B-bp (car (cdr (cdr (cdr (cdr (cdr (cdr (cdr (cdr (cdr B-B-dbp)))))))))))
 (setq B-B-ListeAdmis (vlax-safearray->list (vlax-variant-value (vla-get-AllowedValues B-B-bp))))
 (setq B-B-ListeAdmis (mapcar 'vlax-variant-value B-B-ListeAdmis))
 (vla-put-value B-B-bp (strcat D-Base " m"))
 (setq B-B-bp (car (cdr (cdr (cdr (cdr (cdr (cdr (cdr (cdr B-B-dbp))))))))))
 (vla-put-value B-B-bp (strcat H-Base " m"))
 );foreach
); fin
Ok so now like it only doesnt work in the full code. Also the part not working happens
here :
Part of Code working
(defun c:BB (/ pt5 B-B-blk B-B-dbp)
 (initget 1 "1.50 1.55 1.60 1.65 1.70, 1.75 1.80 1.85 1.90 1.95 2.00")
 (foreach
               (vla-get-modelspace
 );foreach
); fin
Well I kepted looking into it and I have more information. I ran the code and it won't work but if i go back in the Vlide and do Load Selection it works.. This is weird...
And now I tried something else and the code works but I'd like to understand why it does that.
I took (BaseBeton) in the main code and moved it up top and it works.
WHAT THE HELL.....
Cant really test your code. dont have the complete list of your blocks to test it to.
Well i'd be glade to send you everything. Do you have an e-mail that I could send it to ?
No worries, not a big deal CadFrank.
Your code working for you anyways. :)
Cheers
  • 2 years later...
I have the same error when requests very strong the computer with :
(wile (progn .... (setq gr (grRead T 15 0)  vt (cadr gr)  cd (car gr) ) .... )
) ; wh
But I found this : http://www.theswamp.org/index.php?topic=24940.0
and I introduce (gc) in while loop and works fine in AutoCAD 2013 .
