Hello
When I use linear the letter are verry small
It is verry difficult to read how long the line is!
how can i change that!!
Hello
Change your dim text height. If I understand you right.
thnks for the replay
but could you tell me how
mitchell,
you change the dimension style. create a new one with a larger text height & apply it. check out this website for further information.
dailyautocad.com/autocad/dimension-style-settings-1-anatomy-of-a-dimensioning-object%E2%80%A6/
If you are just after finding out how long a line is, you don't have to dimension it to get an answer, just use the command DISTANCE. pick each point you want, and the distance will be displayed on the command line.
thanks for the information but the "problem" is the demension text is to small to read normal. I must explod the draw to so how lang the line is!!
mitchell
you should either increase the text height good enough or annotate your drawing. Just scale the new dimension style to 10 or more & apply it.
you should be fine with it.
Note: You have to go to the "Fit" tab in Dimension Style dialogue box & then increase the 'Use Overall Scale of' option to 10 or more in the 'Scale for dimensions features'. Try it.
Hello
Are you dimensioning in Paperspace or Modelspace?
if in PS, Create just one DIMSTYLE with a text height of at least 2mm (standard) then dimension the objects in the Viewports, you'll have a uniformity in dimensioning even on different scaled viewports.
If you are in MS i suggest you explore Annotative Dimensioning.
You could also OPT for making different dimstyles for different scales but why bother when there's an easier way.
:wink:
