How do i draw a leader with all 90 degree angles. When i'm drawing a leader with an arrow for example and select two points it makes an angle.
Thanks
I would press to activate the Ortho mode.
Or, there is something into your question that I didn't understood? Then, please post a picture with what you are looking for.
Mircea's way works, or you can adjust the LEADER SETTINGS to suit.
Start the LEADER command > S for settings and you will get the displayed dialog box where you can customize all manner of things.
Once set they will stay like that unless changed again in the settings box.
I believe this setting is stored in the drawing, and is not in the system variables. Could be wrong about that.
Edited by Dadgad
Good observation Dadgad about angles constraining option! I didn't know that.
Thanks, seems no matter how much one knows there is always something more to learn, eh? Which makes me very happy! :beer:
Edited by Dadgad
