michael256 Posted June 19, 2012 Posted June 19, 2012 how do i make it so when i select and annotative dimension, how do i make it so that i do not see it in several diffrent sizes.. I am new to annotative dimensioning, i was under the impression that when you un check the "thunder bolt annotative logo" that i highlighted, that would prevent this from happening. Thanks im advand for any help. Quote
SLW210 Posted June 19, 2012 Posted June 19, 2012 I moved your thread to the AutoCAD 2D Drafting, Object Properties & Interface forum. Please stop creating new threads. Quote
nestly Posted June 19, 2012 Posted June 19, 2012 i was under the impression that when you un check the "thunder bolt annotative logo" that i highlighted, that would prevent this from happening. The "thunder bolt" controls whether Annotative objects will be displayed, even if they don't have the current scale. rkent posted the variable that controls whether all the scales are displayed when the object is selected. Quote
