Jeff Bowlin Posted June 19, 2012 Posted June 19, 2012 I have some soil boring data captured, in the field, to an Excel spreadsheet; basically, a bore site ID and coordinates. I'd like to be able to have the coordinate attributes of blocks inserted into my bore site plans populate automatically, perhaps based off of the value of a bore site ID attribute which is manually entered for each bore site. Alternatively, if there were a way to insert the bore site blocks based off the actual Excel records, populating all attribues and locating the block by the actual X,Y,Z coordinate, that might be even better. Is there an easy way? Is there any lisp to be shared? Newbie Quote
spiff88 Posted June 20, 2012 Posted June 20, 2012 This is some VBA code you can use from Excel to insert blocks into AutoCAD. You should have a block already created into AutoCAD. If the block has attributes, you can use the data from Excel to populate the attributes. If you know how VBA and the VBE works, you should have no problem with this. Just make sure to set the 'reference' to AutoCAD. In the VBE - Tools / References - with AutoCAD 2010 it is called AutoCAD 2012 Type Library. Sub InsertBlockWithData() Dim objApp As AcadApplication: Dim objDoc As AcadDocument Dim blockRefObj As AcadBlockReference: Dim varAttributes As Variant Dim InPt(2) As Double ' Excel worksheet name with data to insert into AutoCAD ' X / Y / Z / Layer Name / Block Name / Boring ID / Block Size / Block Rotation DataSheet = "WorksheetWithData" ' Create the link to AutoCAD - the currently open drawing Set objApp = GetObject(, "AutoCAD.Application"): Set objDoc = objApp.ActiveDocument ' Loop through the data - set StartRow (usually 2) and EndRow (last row of data) For Row = StartRow To EndRow ' get coordinates and layer name for text insertion InPt(0) = Worksheets(DataSheet).Cells(Row, 1) InPt(1) = Worksheets(DataSheet).Cells(Row, 2) InPt(2) = Worksheets(DataSheet).Cells(Row, 3) Layer = Worksheets(DataSheet).Cells(Row, 4) BlockName = Worksheets(DataSheet).Cells(Row, 5) BoringName = Worksheets(DataSheet).Cells(Row, 6) Size = Worksheets(DataSheet).Cells(Row, 7) Rotation = Worksheets(DataSheet).Cells(Row, ' in radians ' Insert Borings Block object and change attributes Set blockRefObj = objDoc.ModelSpace.InsertBlock(InPt, BlockName, Size, Size, Size, 0) blockRefObj.Layer = Layer blockRefObj.Color = acByLayer ' set attributes - you can have more than one... varAttributes = blockRefObj.GetAttributes varAttributes(0).TextString = BoringName Next Row End Sub Quote
fiddleback143 Posted May 13, 2013 Posted May 13, 2013 I think I'm doing something wrong I get a run error when I try this on Inpt(0). I changed out "w2orksheetwithdata" to "Creek" which is the tab name. What alse do I need to do? I can send the file or post it somewhere if I need to. Quote
satishrajdev Posted May 14, 2013 Posted May 14, 2013 I have some soil boring data captured, in the field, to an Excel spreadsheet; basically, a bore site ID and coordinates. I'd like to be able to have the coordinate attributes of blocks inserted into my bore site plans populate automatically, perhaps based off of the value of a bore site ID attribute which is manually entered for each bore site. Alternatively, if there were a way to insert the bore site blocks based off the actual Excel records, populating all attribues and locating the block by the actual X,Y,Z coordinate, that might be even better. Is there an easy way? Is there any lisp to be shared? Newbie I also used to insert blocks from X Y Z coords, but just want to have a look how you want to insert blocks, can you attached example drawing and csv for that, So i can modify my lisp as per your requirement.... Quote
