gerryc Posted June 20, 2012 Posted June 20, 2012 Hi, Is it possible to import either Step or Iges files into either AutoCad 2005 or 2010? thanks, gerry Quote
JD Mather Posted June 20, 2012 Posted June 20, 2012 No, you need AutoCAD 2013 or AutoCAD 2000 (or something back towards the last century). But you are in luck. You can convert STEP or IGES to dwg in free Inventor Fusion http://labs.autodesk.com or attach the file(s) here and I suspect someone with 2013 will convert for you. Quote
gerryc Posted June 21, 2012 Author Posted June 21, 2012 I downloaded Inventer-Fusion. Works great. Thanks for your help Gerry Quote
