beerboy Posted June 21, 2012 Posted June 21, 2012 What I am trying to do is check all the instances of Autocad that are running and check for all of the open documents in each one. I have this working in VB6 but .NET is giving me problems. I can get the MainWindowTitle but the other documents open for that instance I have not been able to figure out. Sorry if this has been posted before but I am not sure if I am even on the right track. Any suggestions for this in .NET? I would prefer not to use GetObject(, "Autocad.Application"). Thanks Everybody Quote
btraemoore Posted June 21, 2012 Posted June 21, 2012 Just out of curiosity, why don't you want to use the getobject method? Quote
beerboy Posted June 22, 2012 Author Posted June 22, 2012 Because it does not want to work, I was looking for other options, I wanted to move out of the VB6 era. I am using VS2008 so I may not have any other options. I am trying to find out. Thanks again. Quote
BlackBox Posted June 22, 2012 Posted June 22, 2012 FWIW - You may find this old post useful as an example of how to get an existing instance, or create a new instance of an application: Sounds like you need to check for an active process, prior to creating a new instance. Here's a VB.NET snippet from one of my projects, for you to pull from: Imports Excel = Microsoft.Office.Interop.Excel Imports Microsoft.Office.Interop Imports System.Diagnostics Imports System.IO Module FOO Sub Excel_Foo() Dim xlApp As Excel.Application Try [color=seagreen]' Look for an existing process, if available getObject[/color] If Process.GetProcessesByName("Excel").Length > 0 Then xlApp = CType(GetObject(, "Excel.Application"), Excel.Application) [color=seagreen]' Else createObject[/color] Else xlApp = New Excel.Application End If [color=seagreen] ' <-- Do something[/color] Catch ex As Exception Finally xlApp = Nothing End Sub End Module Quote
beerboy Posted June 22, 2012 Author Posted June 22, 2012 It is the Do Something I am trying to figure out. This returns the MainWindowTitle AutoCAD Map 3D 2010 - [Drawing1.dwg] First instance AutoCAD Map 3D 2010 - [A5119.DWG] Second Instance If I have multiple files open in each instance I want the WindowTitle for each one. Dim p() As Process = Process.GetProcessesByName("Acad") ForEach proc As Process In p Debug.Print(proc.MainWindowTitle) For Each AcadDocument in proc...? Next Iterate through each instance and each document and return the window title. Quote
BlackBox Posted June 22, 2012 Posted June 22, 2012 Instead, why not simply iterate the Documents Collection for each instance of AutoCAD? Perhaps this will be helpful: Control the Drawing Windows Quote
BlackBox Posted June 22, 2012 Posted June 22, 2012 One step further... Iterate through a Collection Object Quote
beerboy Posted June 22, 2012 Author Posted June 22, 2012 What if none of these will import? 'Imports Autodesk.AutoCAD.Runtime 'Imports Autodesk.AutoCAD.ApplicationServices 'Imports Autodesk.AutoCAD.DatabaseServices 'Imports Autodesk.AutoCAD.EditorInput Quote
BlackBox Posted June 22, 2012 Posted June 22, 2012 Then you're missing Assembly Reference(s). ... In Solution Explorer, Select the 'Show All Files' button, and expand the References node... Within, you should have AcDbMgd.dll, and AcMgd.dll added (be sure they both have 'Copy Local' = False in the Properties window). If you do not know what these Assembly References are, see this thread. Quote
BlackBox Posted June 22, 2012 Posted June 22, 2012 I just remembered you're attempting to write an Application outside of AutoCAD... The code being referenced (from the developer help) assumes you are coding a plug-in to load/run within AutoCAD. Quote
beerboy Posted June 25, 2012 Author Posted June 25, 2012 This is a File Manager Applicatio which clients reference an index of documents stored in an Access mdb file. The app allows them to check out, check in or copy files. If a client attempts to check in a file that is open in Autocad he/she receives a message from the app to save and close the file first. This only checks to see if the file is open. It does nothing inside of Autocad or to the file. Here is the VB6 code for this function. Public Function AcadLink() As Boolean Dim i As Integer Dim DwgName As String Dim hWndMain As Long Dim appverfile As String Dim lstItem As String Dim strappver As String AcadLink = False On Error GoTo nocad Set AcadApp = GetObject(, "AutoCAD.Application") ' Debug.Print AcadApp.Name ' Debug.Print AcadApp.FullName ' Debug.Print AcadApp.hWnd ' Debug.Print AcadApp.Caption ' MsgBox ("*" & AcadApp.Caption & "*"), vbOKOnly Set fso = CreateObject("Scripting.FileSystemObject") appverfile = strAppPath & "ClientAutoCadVersion.rpt" If bFileExists(appverfile) Then Open appverfile For Input As #filenum Do Input #filenum, lstItem If UCase(lstItem) = UCase(Left(AcadApp.Caption, Len(lstItem))) Then strappver = Left(AcadApp.Caption, Len(lstItem)) End If Loop Until EOF(filenum) Close #filenum DoEvents End If If Len(strappver) = 0 Then appverfile = "\\networkplace\[url="file://\\Dfw1wnh2\Mid-tex_workgroups\gisfmdb\ClientAutoCadVersion.rpt"]ClientAutoCadVersion.rpt[/url]" If bFileExists(appverfile) Then strappver = Left(AcadApp.Caption, InStr(1, AcadApp.Caption, "[") - 4) Open appverfile For Append As #filenum Print #filenum, strappver Close #filenum DoEvents filea = strAppPath & "ClientAutoCadVersion.rpt" fileb = "[url="file://\\networkplace\ClientAutoCadVersion.rpt"]\\networkplace\ClientAutoCadVersion.rpt[/url]" FileUpdate DoEvents End If End If appverfile = strAppPath & "ClientAutoCadVersion.rpt" If bFileExists(appverfile) Then Open appverfile For Input As #filenum Do Input #filenum, lstItem hWndMain = FindWindow(vbNullString, lstItem & " - [" & lstCitem & ".dwg]") If hWndMain > 0 Then AcadLink = True Close #filenum DoEvents GoTo nocad End If Loop Until EOF(filenum) End If For i = 0 To AcadApp.Documents.Count - 1 DwgName = Left(Right(AcadApp.Documents(i).Name, Len(lstCitem) + 4), Len(lstCitem)) If lstCitem = DwgName Then AcadLink = True Exit For End If Next i nocad: End Function Quote
