KarolR Posted June 23, 2012 Posted June 23, 2012 I made a complex sketch, and want to extrude. When i want to select the whole sketch, i position the mouse on the upper left of the screen and drag down and right, but no window is created. And i cannot add segments to the selection, even with pressing SHIFT, because immediately after the first is selected, it is extruded. Third question: you see on the picture i attached that some segments (in red) are connected. how can i connect all the sketch together, so when i will select it everything is selected. Thanks-Karol Quote
JD Mather Posted June 24, 2012 Posted June 24, 2012 Use Feature Patterns rather than Sketch Patterns. Your sketch is missing coincident constraints - run the sketch doctor. Forget window selection of this for extruding - that would not be correct way. If the sketch was correct it would take only one click in the enclosed area (if Inventor didn't automatically detect the close area). Quote
