richard3009 Posted June 25, 2012 Posted June 25, 2012 Is it possible to lock the border/block on the layout so it cant be moved deleted etc, but still be able to edit the attributes Quote
richard3009 Posted June 25, 2012 Author Posted June 25, 2012 Yes I can lock the border, but how do I edit the attributes when it is locked. Quote
richard3009 Posted June 25, 2012 Author Posted June 25, 2012 Im looking for a way to make a template that is non corruptible, so the title etc can be filled in, but the border is protected. Quote
ReMark Posted June 25, 2012 Posted June 25, 2012 Anything you can do someone else can undo. It's just a matter of time and will. Quote
MSasu Posted June 25, 2012 Posted June 25, 2012 This can be achieved easily with an AutoLISP routine; but since you are using LT, this is out of the question. Alternatively may create a dedicated toolbar button – the macro below works only for half of the job, maybe you will be able to fix it to run entirely. ^C^C_LAYER _U [i]BorderLayerName[/i] EATTEDIT [color=red]_LAYER _LO [i]BorderLayerName[/i] _REDRAW[/color] Quote
ReMark Posted June 25, 2012 Posted June 25, 2012 If you really meed that type of stringent control over your drawings then you should look into buying CADVault by CADLock, Inc. http://www.cadlock.com/products/CADVault/ Quote
ReMark Posted June 25, 2012 Posted June 25, 2012 You wanted a solution and I gave you one. You don't want to purchase the software that is your prerogative. I twist no man's arm. Quote
