When toleranceing dimensions we use the Mtext and stack as tolerance. I am trying to modify this routine that I use to place diameter symbols to dimensions. I think my problem is in the (setq tol (strcat, but I can't figure out how to write it. In this code I am putting a +.000 -.002 tolerance. I need the dimension to stay hot. Any help would be appriecated.
(defun c:M2 (/ d1 lijst1 tol oldtxt a new)
(setq d1 (entsel))
(setq d1 (car d1))
(setq lijst1 (entget d1))
(setq tol (strcat "[url="file://\\A1;d1{\\H0.90x;\\S"]\\A1;d1{\\H0.90x;\\S[/url]" +.000^-.002";}\""))
(setq oldtxt (cdr (assoc 1 lijst1)))
(if (= oldtxt "")
    (setq oldtxt "<>")
    (setq a b)
(setq new (strcat oldtxt tol))
(command "dim1")
(command "newtext" new d1)
(PRINC)
Perhaps?
(setq tol "%%C<>{\\H0.9x;\\S+0.001\"^-0.002\";}")
A couple minor edits to make it look the way I need. But works exaclty like I need thanks.
You're welcome!
You may simplify that code:
(defun c:M2( / d1 tol )
[color=red] (while [/color](setq d1 (entsel))
 (command "_dim1"
          "_newtext" [color=red]tol[/color] d1[color=red] ""[/color])
[color=red] )[/color]
That one works well also. Thanks again
You may find this one useful with ssget .... :)
(defun c:test (/ ss i sn e)
 (vl-load-com)
 (if (setq ss (ssget "_:L" '((0 . "*DIMENSION"))))
     (setq sn (ssname ss (setq i (1- i))))
     (vla-put-textoverride
       (vlax-ename->vla-object sn)
