Problem with terminal numbers
Hello Everyone,
I am new to Autocad Electrical and to this forum. I need small help from you all.
I am using Square with Terminal Number(HTC0001). I am trying to insert number in this square. Can I do it? If yes, How? If no, can you tell me is there any way that I can insert number in that terminal.
Thanks in advance
Srinkoo
Don't you have the option to assign a number in the Insert/Edit Terminal Symbol dialog box where it says "Number"?
Yes I did, but I want that number to be displayed inside the square terminal but not outside of it.
Did you select the wrong symbol? Square with Wire Number has the number above the top of the square.
No Remark. I selected square with terminal number (block: HTC001)
I think you will need to modify the original block to either relocate the attribute ReMark indicated or add a new attribute of your own.
Probably the easiest way is to open the block definition using BEDIT and move the attribute. Exit the block editor, saving changes then ATTSYNC the block. If this is to be used in all future uses of the block you should then WBLOCK it out to the symbol library. If it is only for this drawing set you can use Design Centre to pull in the new definition from the modified sheet.
Do I need to edit any other settings
and for the record, HTC0001 displays the number outside the square here too but as the text is the same height as the square it would make no sense to put it inside
What other settings would have to be edited? All you would be doing is moving the location of the attribute wouldn't you?
Dbroada,
As I am new to this.Can you give me step by step procedure on how to insert a number in any ( square, triangle, .. ) terminal.
Thanks in advance
I would reduce the height of TERM01 and make it centre justified but leave everything else alone
I can only do this quickly but highlight one of your HTC001 blocks and type BEDIT
locate the TERM01 attribute and move it to the middle of the square. Note there are a lot of other attributes that look to be in the way but just ignore them.
While that attribute is still highlighted call up the properties palette. Modify the justification and height to suit. I am metric so you will have to find the best size yourself.
Close the block editor.
type ATTSYNC and click on the block you have just modified.
Having done all that I find electrical doesn't always let you keep modifications to blocks. You may find they have all reverted back to OOTB spec when you do a renumber. I never found out why.
BEDIT
Select a block reference. Right-click in the drawing area. Click Block Editor. Make your edits. Close the block editor. You'll be asked if you want to save your changes. Answer "yes".
I got it. Thank you Remark and Dbroada. You both are amazing. Thanks a ton
Dave did the hard work.:thumbsup: I just stood around.:ouch: LoL
