How Do I Browse The Xref To Change Its Path With Acad 09?
Did you look at any of the similar threads listed below? Maybe one already contains the answer. Just a suggestion.
So I Have To Open A Whole New Program Now To Change An Xref Path???!!!!! What A Terrible Waste Of Time!! It Did Not Even Work Right For One Particular Drawing.
Why don't you calm down. There is no need to yell at me.
Open what "whole new program" are you referring to?
How many drawings were you trying to repath?
No you don't need an additional program.
1. Open the External References palette.
2. Highlight the reference file that you want to change.
3. In the Details section, click in the "Found At" field.
4. Either type the new path, or click the tiny button on the right that contains [...]
You must be referring to RefManager, right? Here is what AutoCAD Help has to say in way of a warning:
"Reference Manager is intended primarily for CAD managers who thoroughly understand paths. It changes multiple paths at once, and you cannot undo your actions. Use extreme caution, especially if you are working on a network."
Reference Manager has its own Help files. Did you take a look at them first?
RKM:
For my own education...how would this be different from the procedure for changing a search path as found in the Help file. Is the repathing of a Xref a distinctly different procedure? Thanks in advance for any additional insight you can offer.
I would be interested in this also. We are always getting drawings from Architects, and if we don't put them all in the same folder, we have problems with the main drawing not finding the xrefs associated with it.
Our trouble is, we must put the main drawing in folder A, and all subsiduary drawings are placed into folder A/B, etc
You know you'll get a better answer if you'd be a little more polite, :huh:
I did not mean to seem rude and i greatly request deepest acceptance for my apology
i was actually yelling more at the program then at anyone on this forum; meaning the program was terribly set up and would be a waste time
my problem was answered and in the future i will try to be more direct in my complaints rather flying off the handle
thanks
hi-liter:
We look forward to your future involvement. Stay cool.:)
If your parent drawing is in "C:\Drawings", and your xrefs are in "C:\Drawings\Xrefs" (as an example)... then your saved relative path is going to be "Xrefs\name_of_drawing.dwg"
