kahaduwap Posted June 29, 2012 Share Posted June 29, 2012 How to draw attached drawing using solidworks sheet metal? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 29, 2012 Share Posted June 29, 2012 Welcome to the forum. Being a SOLIDWORKS specific question, you would likely be better served to put it in the SOLIDWORKS forum, where you know that Solidworks users will see it. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 29, 2012 Share Posted June 29, 2012 What version of SolidWorks are you using? 2010? 2011? 2012? How many parts will make up the real world assembly? 1? 4? More? Where are the rips or seams? More information is needed. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 29, 2012 Share Posted June 29, 2012 Moved thread to SolidWorks forum. Quote Link to comment Share on other sites More sharing options...
kahaduwap Posted June 29, 2012 Author Share Posted June 29, 2012 Dear JD, Solidworks standard 2012, no idea about number of assemblies. kahaduwap Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2012 Share Posted June 29, 2012 How much experience do you have using Solidworks? Quote Link to comment Share on other sites More sharing options...
kahaduwap Posted June 29, 2012 Author Share Posted June 29, 2012 How much experience do you have using Solidworks? Only for two months Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 29, 2012 Share Posted June 29, 2012 Dear JD,Solidworks standard 2012, no idea about number of assemblies. kahaduwap Not assemblies. Parts. How many sheets of metal will be folded to make one of these. What is the thickness of the material? I will try to post an example later today of one possible solution. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2012 Share Posted June 29, 2012 Only for two months How many drawings have you done so far of this nature? Quote Link to comment Share on other sites More sharing options...
kahaduwap Posted June 29, 2012 Author Share Posted June 29, 2012 One for top part and four for four bottom sides. Thickness is 0.75 mm Quote Link to comment Share on other sites More sharing options...
