Zykl0 Posted November 1, 2008 Posted November 1, 2008 Hi! I have many layers i would like to see them forced to specific linetypes. Let say; Layers.............Linetypes M-N-INC-25--->Hidden-25 M-N-INC-32--->Hidden-32 I would like to bind this function to a button and each time i click the button it set the layers to the specific linetypes above.. and when i click button one more time it set all these layers back to "By Layer" ... if its not possible i could use 2 button instead but its less impressive Thanks in advance. Quote
lpseifert Posted November 1, 2008 Posted November 1, 2008 used as a learning experience... minimal error checking and testing Edit as necessary BTW... you can't set a layer's linetype to Bylayer, I used Continuous (defun c:test (/ laylist) (setq laylist (list "M-N-INC-25" "M-N-INC-32")) (if (eq (getvar "useri1") 0) (progn (foreach ln laylist (if (tblsearch "ltype" (strcat "Hidden-" (substr ln (- (strlen ln) 1)))) (command "layer" "l" (strcat "Hidden-" (substr ln (- (strlen ln) 1))) ln "") (alert (strcat "Load linetype " (strcat "Hidden-" (substr ln (- (strlen ln) 1))) " first")) );if ) ;foreach (setvar "useri1" 1) ) ;progn (progn (foreach ln laylist (command "layer" "l" "continuous" ln "") ) ;foreach (setvar "useri1" 0) ) ;progn ) ;if ) ;defun Quote
Zykl0 Posted November 3, 2008 Author Posted November 3, 2008 Wow it work really good I would like to understand few things on how it work. i am still at the "hello world" state. (tblsearch "ltype" (strcat "Hidden-" (substr ln (- (strlen ln) 1)))) (command "layer" "l" (strcat "Hidden-" (substr ln (- (strlen ln) 1))) ln "") (alert (strcat "Load linetype " (strcat "Hidden-" (substr ln (- (strlen ln) 1))) " first")) First line, i beleive you are gathering ltype into the *.lin file... one line 2 you force the layer to be on a linetype... line 3 (alert) no idea... Can you please tell me how it work i dont see how you call Hidden-25 line type.. and i would like to add more layer/Ltype in the future Let say M-N-MAIN-100 --to ltype--- CENTER-100 how can i do that? Quote
lpseifert Posted November 3, 2008 Posted November 3, 2008 First line > takes the layer's name, strips all but the last 2 characters and tacks it on to Hidden-, then searches to see if the linetype Hidden-nn is loaded. If it is loaded it sets the layer's linetype to Hidden-nn (line 2). If the linetype is not loaded it skips to line 3 and gives you an alert to load it first. As far as the rest, I suppose it could done, but maybe layer states would be easier. Quote
