Please Help - Comparing DWG files in LT 2013?
JnrCADClaire
Hi,
I'm currently running AutoCAD LT 2013, and I've been asked to compare two dwg files; one has been drawn using LT 2013 and the other has been drawn using an older version of the software.
Is there any way or any plug that can be used in LT 13 to compare the two drawings?
I've looked online and the only program i can find is Furix but that doesnt allow for usage on the LT version of autoCAD.
Please help!
Thanks
Claire
That was my initial thought to be honest; but Id have thought that autodesk or someone would have developed a command or a patch that would make the process pretty painless. Furix have created a compare tool for the full version of AutoCAD but not the LT version.
The "Easy" button is in my boss's office. Wait right there...I'll go get it for you.
Do you have access to AutoDesk Design Review? I think there is a simple comparison feature in that piece of software. I am not 100% sure though.
Please change your profile to read LT 2013 unless you want to get a lot of advice meant strictly for full AutoCAD.
I gave you the only help you can count on using LT...Xref. I personally do not know another way to do it. Did you look into AutoDesk Design Review? Does it have a comparison feature?
Initially, My first comment about wanting genuine help was aimed at your "The "Easy" button is in my boss's office. Wait right there...I'll go get it for you." which was the only thing you'd written before you edited your post and added the rest of your text, to which my response was promptly changed.
If XRef'ing the file is the only option then so be it; i only thought id ask in case someone had any better suggestions.
thank you for your help.
No offense was meant and I can assure you that none was taken.
I'm still searching for additional answers to your question. If I find one I will be certain to post it.
Thank you; I do appreciate it.
my boss is busting my chops about this whole thing lol
I told him that im pretty sure that xref is the only answer lol
Autodesk Design Review works fantastic. Plot both files to a DWFx (identical layouts, of course) and then use the Compare option. I use it all the time when I am in need of comparing updated files from outside clients.
