I am obviously a 3ds max design beginner trying to switch from Sketchup to Max.
I am unable to attach a Mr. sky portal onto an imported Sketchup model, will not attach to face, I’ve tried converting model to an editable poly but portal mesh will not attach in vertical plane only horizontal.
John
I don't have Max loaded on this machine, so I can't run any tests, but I'm wondering why you are trying to do this? If I have time tomorrow I will check into it, but I'm pretty sure that if you attach a sky portal to your model you will lose the ability to make adjustments to it's parameters.
