nate201 Posted November 1, 2008 Posted November 1, 2008 I have a list box that will contain the leg sizes for different angles, then I have radio buttons that I want to choose the thickness from. I want to know how I can pull the leg size with the thickness, get the weight per foot for that angle size (have that info), then I think I can put the rest together. I don't need the code wrote out for me. I just want to know how to do it. I have check tutorials and they show you how to use them separate, but I want to combine after they are selected. This is what I have created so far: DCL: Angle : dialog { label = "Angle"; : text { key = "t1"; value="Please select your angle information"; } : text { key = "t2"; value="and enter your length."; } : row { : boxed_column { label = "Select angle leg size:"; : list_box { key = "legs"; height = 15; width = 17; multiple_select = false; fixed_width_font = true; value = ""; }} : column { : boxed_column { label = "Select thickness:"; : radio_button { key = "1/8"; label = "1/8"; } : radio_button { key = "3/16"; label = "3/16"; } : radio_button { key = "1/4"; label = "1/4"; } : radio_button { key = "5/16"; label = "5/16"; } : radio_button { key = "3/8"; label = "3/8"; } : radio_button { key = "7/16"; label = "7/16"; } : radio_button { key = "1/2"; label = "1/2"; } : radio_button { key = "9/16"; label = "9/16"; } : radio_button { key = "5/8"; label = "5/8"; } : radio_button { key = "3/4"; label = "3/4"; } : radio_button { key = "7/8"; label = "7/8"; } : radio_button { key = "1"; label = "1"; } : radio_button { key = "1 1/8"; label = "1 1/8"; } } : boxed_column { : toggle { key = "galv"; label = "Galvanized"; value = "0"; } }}} : boxed_row { label = "Enter angle length:"; : edit_box { key="ft"; label = "Feet:"; edit_width=6; } : edit_box { key="in"; label = "Inches:"; edit_width=6; } } ok_cancel; } LSP: (prompt "\nType ANG to run.....") (defun C:ANG () (setq legs (list "1 x 1" "1 1/8 x 1 1/8" "1 1/4 x 1 1/4" "1 1/2 x 1 1/2" "1 3/4 x 1 3/4" "2 x 2" "2 1/2 x 2" "2 1/2 x 2 1/2" "3 x 2" "3 x 2 1/2" "3 x 3" "3 1/2 x 2 1/2" "3 1/2 x 3" "3 1/2 x 3 1/2" "4 x 3" ) ) (setq dcl_id (load_dialog "Angle.dcl")) (if (not (new_dialog "Angle" dcl_id)) (exit) ) (start_list "legs" 3) (mapcar 'add_list legs) (end_list) (action_tile "accept" "(done_dialog)" ) (start_dialog) (unload_dialog dcl_id) (princ) ) (princ) They will be more angle sizes added to this, just want know how to put everything together first. Any help would be greatly appreciated. Quote
