My tips(Unterstanding between planner mapping & box mapping)
papagyi
This explanation is one of my reply post from 3d & rendering section.But i think
this is suitable for 3d users....Planner mapping is suitable to use 0 to 30 degree rotation of object.So 45..>..60..90..rotation degree objects are suitable to use box mapping.I show you example dwg.You can see sample dwg ,various types of rotation objects with single material of box and planner mapping styles.You should notice the image of girl hair difference.In drawing ,two roll images for Planner map images,(first roll is 45 ,60 ,90 )and( second roll ,they are rotated to 0 degree).Then three roll of box mapping images (1. box mapping default(reset) ,(2.mapping rotate according to various degree) (3.rotate to 0 degree).Don't forget" picture "material to reattach lady image.Now i give you dwg with textures.
pa.zip
