Bill Tillman Posted November 2, 2008 Posted November 2, 2008 I am using AutoCAD 2009 and followed one of the 3D tutorials. All went well, but when I used the shade command I cannot seem to figure out how to return to the unshaded view, with the wireframe that I started with. Quote
ReMark Posted November 2, 2008 Posted November 2, 2008 Visual styles: 2D wireframe. Should be in the Dashboard. Quote
papagyi Posted November 2, 2008 Posted November 2, 2008 For your 2d wire frame view, type in command line "sha" enter "2" enter."Vscurrent" can use instead of "sha".When you type "sha" you will see [2dwireframe/3dwireframe/3dhidden/Realistic/conceptual/other] :..... you should test for choice all options how they work in view effect.Another way ,you can use "visual Styles " toolbar. Quote
papagyi Posted November 2, 2008 Posted November 2, 2008 Visual styles: 2D wireframe. Should be in the Dashboard. Ribbon tool use instead of dashboard in Acad 2009. Quote
ReMark Posted November 2, 2008 Posted November 2, 2008 Agreed (re: 2009) but poster is using 2007. Thank you. Quote
Strix Posted November 3, 2008 Posted November 3, 2008 well their profile says 2007, but the post says 2009 maybe Bill could clarify for us? Quote
