thronedflame Posted July 10, 2012 Share Posted July 10, 2012 Hi I want to use the revolve feature to revolve a parabola, creating a nose cone type object. However it won't let me. I figured a parabola line, with a center line would work, but it says the object is open. So I tried connecting all the lines but it says that a single center line should be used. Can someone help me out? Thanks Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 10, 2012 Share Posted July 10, 2012 You using AutoCAD or Solidworks? Can you post what you have so far? If Solidworks, what version of Soliworks? Quote Link to comment Share on other sites More sharing options...
thronedflame Posted July 10, 2012 Author Share Posted July 10, 2012 Its solidworks. Its the 2010 version. What do you mean as far as posting what I have so far? do you want me to attach the file? Quote Link to comment Share on other sites More sharing options...
thronedflame Posted July 10, 2012 Author Share Posted July 10, 2012 Not entirely sure how to resize it Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 10, 2012 Share Posted July 10, 2012 Yes, attach the file, much easier to work with your parabola to find the problem. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 10, 2012 Share Posted July 10, 2012 What method did you use to create the parabola? Quote Link to comment Share on other sites More sharing options...
thronedflame Posted July 10, 2012 Author Share Posted July 10, 2012 I used Tools > Sketch Entities > Parabola Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 10, 2012 Share Posted July 10, 2012 Have you at least gone through the Help>Tutorials. Your profile is open - you could use the Surface Revolve and then Thicken or close off as shown and then Trim excess (Solidworks will still see as open profile because of center line is also construction linetype in SWx - but it will offer to close the profile for you and revolve. If you want a Thin feature then Shell the part after the Revolve. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 10, 2012 Share Posted July 10, 2012 So I tried connecting all the lines but it says that a single center line should be used. You didn't show this image. Did you use only one center line? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 10, 2012 Share Posted July 10, 2012 You need to close as indicated. [ATTACH=CONFIG]35867[/ATTACH] Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 10, 2012 Share Posted July 10, 2012 ...or do a Surface Revolve. Quote Link to comment Share on other sites More sharing options...
thronedflame Posted July 10, 2012 Author Share Posted July 10, 2012 I tried both approaches. Neither worked. I want it to be a thin feature. Is that problem? Quote Link to comment Share on other sites More sharing options...
thronedflame Posted July 10, 2012 Author Share Posted July 10, 2012 I get rebuild error: sketches used for revolve features use a single, non-self intersecting contour, and either a single center line, or one that is currently selected. Also I dont have the surfaces tab. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 10, 2012 Share Posted July 10, 2012 Right click on your file name and select Send to Compressed (zipped) Folder and attach the resulting *.zip file here. On this particular revolution I could not do a Thin Feature in the revolve. I had to Revolve and then Shell or Surface Revolve and Thickne. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 10, 2012 Share Posted July 10, 2012 To get Surfaces tab right click on any other tab and select Surfaces or Insert>Surface>Revolve Quote Link to comment Share on other sites More sharing options...
thronedflame Posted July 10, 2012 Author Share Posted July 10, 2012 Ok I got the surface to revolve, both ways actually. And I was able to make it a shell. But is there a way to get rid of the bottom surface so that it is open? Quote Link to comment Share on other sites More sharing options...
thronedflame Posted July 10, 2012 Author Share Posted July 10, 2012 Aside from just making a extruded cut using a circle i mean Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 10, 2012 Share Posted July 10, 2012 When you Shell you click on the faces you want to remove (in this case the bottom face). Quote Link to comment Share on other sites More sharing options...
thronedflame Posted July 10, 2012 Author Share Posted July 10, 2012 Excellent. Thank you! Quote Link to comment Share on other sites More sharing options...
