Hello everyone, I got this drawing thats saved in the model tab, when I want to switch to layout tab, it lags and crashes, does anyone know what could be the cause/root of this issue, if not, what would be the best way to work around it? restore a previous version? delete the layout tab, and do it all over again? cheers for all your help in advance.
Try running -PURGE at the commandline
and make sure you include the hyphen.
Command: -PURGE
Enter type of unused objects to purge
[blocks/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SH
apes/textSTyles/Mlinestyles/Tablestyles/Visualstyles/Regapps/Zero-length
geometry/Empty text objects/All]: r
Enter name(s) to purge :
Verify each name to be purged? [Yes/No] : n
Deleting registered application "ACAD_DSTYLE_DIM_EXT1_LINETYPE".
Deleting registered application "ACAD_DSTYLE_DIM_EXT2_LINETYPE".
2 registered applications deleted.
Command:
-PURGE
geometry/Empty text objects/All]: a
Deleting block "*D10".
Deleting block "*D11".
2 blocks deleted.
No unreferenced layers found.
No unreferenced linetypes found.
No unreferenced text styles found.
No unreferenced shape files found.
No unreferenced dimension styles found.
No unreferenced mlinestyles found.
Deleting plotstyle "0.18".
1 plotstyle deleted.
No unreferenced table styles found.
No unreferenced materials found.
No unreferenced visual styles found.
No unreferenced multileader styles found.
No unreferenced groups found.
Command:
-PURGE
geometry/Empty text objects/All]: *Cancel*
Command:
Command: _qsave
Command: AUDIT
Fix any errors detected? [Yes/No] : y
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Error for Entry (35873) eInvalidInput was Removed.
Pass 1 800 objects auditedAcDbSolid(379F9) XData Handle Unknown
Null
AcDbSolid(37A15) XData Handle Unknown Null
Pass 1 2600 objects audited
Auditing Entities Pass 2
Pass 2 2600 objects audited
Auditing Blocks
48 Blocks audited
Total errors found 9 fixed 9
Erased 0 objects
Command: SAVE
Yeah I tried that already and it didn't work...
Is this a drawing which you did, or somebody else?
Do you know what software it was done with?
Have you tried the RECOVER option before opening it?
I dont know who or where the drawing came from it was just given to me from somebody at work. But I ended up running the RECOVERALL command like u said and it seems to work fine. Thankyou for your help, I don't know why I didn't think of it before. to stressed out these days... cheers!
Excellent, glad you are back in the game. :beer:
