Blam Posted July 16, 2012 Posted July 16, 2012 What would be the easiest way to create a 3-dash line for a drawing? I have a user with a need for a 3-dash line. Like a phantom line but with 3 dashes. I know how to edit the pen-up, pen-down settings in a .lin file. But then what would be the best way to handle the new line when it is sent to the client? Would I need to create a custom line file and sent it with the .dwg files or could I edit the acad.lin file? Would the receiver run into problems with missing linetypes? Quote
SLW210 Posted July 16, 2012 Posted July 16, 2012 Linetypes are stored in the drawing (in a table). Quote
ReMark Posted July 16, 2012 Posted July 16, 2012 You can copy and edit an existing linetype definition or create a whole new one using the Express Tools command MAKELTYPE. The linetype is embedded in the drawing that you send to the client. You don't have to send him a copy of your .lin file. Quote
Blam Posted July 16, 2012 Author Posted July 16, 2012 What would happen in this scenario: Say the receiver gets Drawing 1 that has the 3-dash line in it and Drawing 2 that does not. If he wanted the 3-dash line in Drawing 2, could he copy and paste it from Drawing 1 to "import" it? Quote
ReMark Posted July 16, 2012 Posted July 16, 2012 The Phantom linetype already has two dashes. Use that as the basis for your three dash linetype. Quote
nestly Posted July 16, 2012 Posted July 16, 2012 You can use Phantom definition as the template, but make sure you use a unique linetype name. To import the new linetype into another drawing, use DesignCenter as mentioned above, or simply drag-n-drop or copy/paste any object using that linetype into the other drawing. Quote
