nativedog Posted July 18, 2012 Posted July 18, 2012 I recieve this error when trying to detach this dwg. "Xref X-H- MECHANICAL ESE1 has multiple references. Not detached." Can anyone explain to me how to detach this xref correctly? Thanks in advance! Quote
SLW210 Posted July 18, 2012 Posted July 18, 2012 Are there instances of this xref in Paperspace (Layout Tab)? Quote
RobDraw Posted July 18, 2012 Posted July 18, 2012 You need to erase all or all but one of the XREFs referring to that file before you can detach. Quote
nativedog Posted July 20, 2012 Author Posted July 20, 2012 sorry, havent been able to get back here for a day or two. No there no instances of this xref in paperspace. It is in model space only. Quote
Print_Master Posted July 20, 2012 Posted July 20, 2012 You could bind it and then just delete it off the drawing in model space. Quote
Lee Roy Posted July 20, 2012 Posted July 20, 2012 1. Select Xref 2. Select Similar 3. Delete 4. Detach Quote
