MichaelH27 Posted July 19, 2012 Posted July 19, 2012 I have tried to create a linetype from lines and text. I have drawn lines and enetered "E" at equal spacings. This is what I want to use as my linetype for a buried elec line. I have used the express menu "make linetype" and it didnt work. Why didnt it work? Why is this so difficult? Why is there "secrets" to building this stuff? Attached is a jpg of my headache. Thanks, Mad Michael Quote
MSasu Posted July 19, 2012 Posted July 19, 2012 Something like this? *BELECTRIC_LINE,Buried electric line ---E----E----E----E----E--- A,.5,-.2,["E",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.04 Quote
MichaelH27 Posted July 19, 2012 Author Posted July 19, 2012 Yup, nice one! How can I increase the size of the "E"s? and make the lines a little bit longer? I have no idea how to read that code. I copy and pasted your code into notepad and created a .lin file from that, loaded it up and yes.... thats what I want it to look like but need to do a few little changes and then I can use it to create other linetypes. Quote
MSasu Posted July 19, 2012 Posted July 19, 2012 Try to play with blue number for line size, respectively with red ones for label appearance: *BELECTRIC_LINE,Buried electric line ---E----E----E----E----E--- A,[color=blue]3[/color],-.2,["E",STANDARD,S=[color=red].3[/color],R=0.0,X=-0.1,Y=[color=red]-.15[/color]],[color=red]-.17[/color] Quote
MichaelH27 Posted July 19, 2012 Author Posted July 19, 2012 I've done soemthing wrong, I was playing around with the numbers in the code and figured them out somewhat, but then it dawned on me that my ltscale is set to 50. In the jpg I attached, you can see the 2 lines with a centrex2 linetype. one runs north/south the other east/west/. The distances of those lines are 804.68m you can see the little green squares, those are 90m x 90m with a hiddenx2 linetype. In order for me to see the linetypes that I want, I changed the ltscale to 50. If I make the ltscale 1, You cant see the linetypes. Is the proper way to leave the ltscale set to 1? If so, How can I generate the linetypes to show up in the jpg without messing with the ltscale? Also having a problem with plotting. I have NOTHING in the preview window, no idea whats going on with this, another problem thats going to creep on me until I get to it.... ugggghhhh Quote
