hertz hound Posted July 21, 2012 Share Posted July 21, 2012 I am having a problem with dimension lines and text coming out to thick when plotted or exported to a pdf. I first thought the problem was because I used my own dim style and dim text style (non-annotative). So I tried again with the standard dim style (annotative) and I am having the same problem. Everything looks great in a model space view, and still looks great when I drag the view to a sheet. I can see the problem when I do a plot preview. And it looks just as bad when I plot it. I tried for a little bit to change the line type scale in the dim style but that didn’t help. I think I was using the regular dimensioning tool and not the AEC dimensioning tools. I am using the AECB sheet template that has been modified for the title block and nothing else. I don’t think it is possible the paper space view port is scaled to big? There is five view ports scaled to ¼” = 1’, plus a table that was placed on the sheet not in a viewport, all on a 24x36. The table has the same problem as the dimensions. Does anybody have any ideas? The drawing is due Monday!!! Quote Link to comment Share on other sites More sharing options...
tzframpton Posted July 21, 2012 Share Posted July 21, 2012 Check your Plot Style. Quote Link to comment Share on other sites More sharing options...
