Finding the divisibility of a number by another is possible in other languages (like Java and C#). Is it possible in Lisp too?.
I shall be thankful for any help.
Edited by aloy
There are a few ways to go about this, but LISP does not have many of the same Methods .NET languages do... Unless one code their own LispFunction Method and NETLOADs the resultant assembly. But we'll leave that for another thread.
One way, would be to convert the real to a string with RTOS, then to split the string into the suffix (right of decimal) using vl-String-Left-Trim and vl-String-Search, then convert that sub-string to a real again (you may need to STRCAT a preceding zero?).
HTH
Wouldn’t that be the REM built-in function?
(rem 5 3)   ;return 2
Is that was what you were looking for? Or did I missed something in your request?
Yes Msasu, thats the one.
I actually wanted to go through a list which contains chainages, the X and Y coordinates attached to each chainage on a road centre line. The goal is to prepare a table giving the chainages in a column and indicate X and Y values against them in the table. I want to put a remark in another column when the remainder after division of chainage by spacing of chainages (25 or 20 as the case may be) is not zero. I will post another thread about this table later.
Thanks
Thanks RenderMan,
The reply from MSasu can be used for my purpose. I actually did something like what you mentioned in your second para when I wanted to prepare a table giving chainages, X and Y values attached to variables. That was way back in early 90s.
Regards,
Aloy
Thanks for reminding me of this, Mircea (I forgot all about it! LoL).
