Hi I was wondering if anyone had a script or lisp routine that
can change the layer of blocks I have drawn up to layer '0'
basically I have a quite a few blocks in a folder that I need to change thier from layer 'detail' to layer '0'
I know i can do it manually but there are hundreds of blocks , so it will take me for ever
I would appreciate any help
thanks
Dadgad, i don't think Lee lisp will work for this situation.
OP, am i correct in thinking that you want change all blocks in you drawing that are on layer "detail" to layer "0"
if so a simple script will work.
ssx  block * layer detail
chprop p  la 0
qsave
chprop p  la 0
qsave
Yeah, looks like you are right, I figured Lee probably had something that would do it, but just looked, and nothing jumped out at me.
Your succinct little script looks like a real good fit though! :beer:
  • 3 months later...
Just saw this, so I'm guessing you've already done it manually.
Sounds like your blocks are all in a folder, they are dwg files, right? You can use 3 common apps to generate your script. First, use the windows command window to get a list of the files. Second, paste it into Excel and add other columns with the commands you want to run...open, zoom extents, chprop, purge detail layer, qsave, close, etc. Use a CONCATENATE funtion to string them all together. Copy paste the concatenate results into Notepad and save as a script (.scr) Then run the script in AutoCAD.
I do this to write scripts that adjust images, update block attributes, insert blocks, etc. Might not be worth your time unless you'll use it again and again.
  • 2 weeks later...
Jasenc,
I've been using this lisp routine by CAREN LINDSEY for years. It works a treat.
;    UPDATE BLOCK LAYER (updblkly.lsp)
;    PRE-INSERTED BLOCK DEFINITION CLEAN-UP UTILITY
;    This routine is especially usefull to redefine pre-inserted blocks whose
;    colors and layers need to be changed to layer 0 and color BYLAYER.
;       This routine allows the user to update the layer of
;    all entities within a block to a single layer (exam: layer=0)
;    without the user having to explode the symbol.  By default the color of
;    all entities are changed to BYLAYER. The routine changes the original
;    definition of the block within the current drawing.
;    To use this routine the user is asked to specify a single
;    layer to place all entities of a selected block(s).
;    The user is next prompted to select one or more blocks to update. The routine
;    then redefines all entities of the block to the layer specified.
;    When the user regenerates the drawing she/he will find that all
;    occurances of the block have been redefined.  This is because the
;    original definition of the block is changed!!!
;    IF YOU FIND THIS ROUTINE USEFUL PLEASE E-MAIL ME AT lindseycc@aol.com
;       by CAREN LINDSEY, June 1993
;INTERNAL ERROR HANDLER
(defun err-ubc (s)                ; If an error (such as CTRL-C) occurs
                       ; while this command is active...
   (if (/= s "Function cancelled")
         (princ (strcat "\nError: " s))
   (setq *error* olderr)            ; Restore old *error* handler
);err-ubc
(DEFUN C:UDL (/ BLK CBL CBL2 C ACL ALY L NLY NCL YN)
   (setq olderr *error* *error* err-ubc)
       (while (null L)
       (setq L (strcase (getstring "\nEnter new layer name: ")))
       (cond
           ((= L "")(setq L nil))
           ((null (tblsearch "LAYER" L))
               (princ (strcat "\nLayer " L " does not exists!"))
               (initget "YES yes NO no")
               (setq yn (strcase (getstring "\nCreate new layer (y/n)? ")))
               (if (= yn "Y")(command ".layer" "m" L "")(setq L nil)))
       );cond
   );while
   (PROMPT "\nPick blocks to update. ")
   (SETQ SS (SSGET '((0 . "INSERT"))))
   (SETQ K 0)
   (WHILE (< K (SSLENGTH SS))
           (setq CBL (tblsearch "BLOCK" (CDR (ASSOC 2 (ENTGET (SETQ BLK (SSNAME SS K)))))))
           (SETQ CBL2 (CDR (ASSOC -2 CBL)))
       (WHILE (BOUNDP 'CBL2)
           (SETQ EE (ENTGET CBL2))
           ;Update layer value
            (SETQ NLY (CONS 8 L))
           (SETQ ALY (ASSOC 8 EE))
           (SETQ NEWE (SUBST NLY ALY EE))
           (ENTMOD NEWE)
           (SETQ CBL2 (ENTNEXT CBL2))
       );end while
       (ENTUPD BLK)
       (SETQ K (1+ K))
   );end while
);end updblkly
