I am looking for a lisp that can Sum up all the dimension & give a singlevalue so that I can easily get quantity of lines....
Check this ... :)
(defun c:Test (/ ss n)
 (if (setq ss (ssget '((0 . "*DIMENSION"))))
   (progn (setq n 0)
          ((lambda (x / sn)
             (while (setq sn (ssname ss (setq x (1+ x))))
               (setq n (+ (cdr (assoc 42 (entget sn))) n))
            -1
          (if (> n 0)
            (alert (strcat "Total value of seleced Dimensions is : <"
                           (rtos n 2)
Here is a very simple solution:
(defun c:dimsum ( / i s x )
   (if (setq s
           (ssget
              '(   (0 . "DIMENSION")
                   (-4 . "<OR")
                       (70 . 000)
                       (70 . 001)
                       (70 . 032)
                       (70 . 033)
                       (70 . 128)
                       (70 . 129)
                       (70 . 160)
                       (70 . 161)
                   (-4 . "OR>")
           (setq x 0.0)
           (repeat (setq i (sslength s))
               (setq x (+ x (cdr (assoc 42 (entget (ssname s (setq i (1- i))))))))
           (princ (strcat "\nTotal of " (itoa (sslength s)) " Dimensions: " (rtos x)))
Edited by Lee Mac
Thanks for the LISP. It works great. If there are edited dimension while calculating it should prompt saying that whether to inclue text override or not?
Thanks
Tanveer
So close... if the Dim's text has been moved, the Lisp routine will not count it. I had to do a DimTedit, Home on all the dims before this gave the correct Sum.
Also, it's uses the full precision, not the precision of the dim.
Eg, if I have four 99.5mm dims, all rounded down, I'd expect the sum to be 396 (not 398) which lets me know I've got to round up 2 of the dims.
I had overlooked the combination of bit-codes 2 & 8 and have now updated the above code.
The program will use the precision set by the LUPREC System Variable.
