I was wondering how to use dimensions from a lisp routine. I have a lisp that creates a custom dim style, but then I would like for it to start the dimension command. I have the "_dimlinear" in the lisp, but it doesn't allow me to pick my points. What is the command line for allowing a command to get user input in lisp like that? Thanks!
Anything like this should work:
(defun c:dimtest (/)
   (command "_dimlinear"
       pause
       pause
       pause
Well, it works for me anyway - but then I am using ACAD 2004, and not 09 like you - therefore the command syntax for a linear dimension may be slightly different.
But let me know if this helps in any way :)
Hard to tell without seeing the code but try this...
try putting this after the line calling dimlinear
(while (> (getvar 'CmdActive) 0) (command pause))
Awsome! The "pause" worked just the way I wanted it to! Thanks guys!
I didn't want to start another thread for this if I didn't have to, but another question I have is about purging. I would like to figure out a lisp that is something like this...
If "X" dimstyle exists, purge it. If nonexistent, continue with the lisp."
How can I accomplish that?
(if
(tblsearch "dimstyle" "x");predicate
(command "-purge" "d" "x" "n");if true do this [may need another "n"]
(progn                                       ; if false do this
 (code)
);progn
);if
It may give you an error if the dimstyle is referenced
