Autocad 2010 door/window assembly does not show on 3D wall
Hello,
I have a 30 cm wall (composed of 2 components).
When I add a door/window assembly (which is a window) the window does not appear in realistic visual style 3D.
some walls are OK and some walls with same style does not show any window when displaying Realistic Visual Style 3D.
Please help.
Hello all,
I found the reason for that case. A warning on the wall (the known yello triangle) prevents the windows to be displayed on 3D.
Please advise if this can be override so the window will be displayed even if there is a warning on the wall.
Thanks.
