CaveMan
AutoCAD Tables Data Extraction
CaveMan
Good Day
looking for assistance with extracting data from an AutoCAD table.
Hav found a fex examples on how to create a table in AutoCAD with VB.Net but no luck on how to loop through the rows and columns in an AutoCAD table and see the items within. Want to be able to loop through a list of drawings, open drawings find the table in Paper or Model space, loop through the records and export them to excel - SQL or XML, or even a simple method of creating a collection if records in VB.Net, where one colud then export the list
Any assistnace most welcome
Regards
Share this post
Link to post
fixo
Give this a try, change full path of folder and CSV file name
at the start of command WTB
Imports System
Imports System.Text
Imports System.IO
Imports System.Data
Imports System.Linq
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.ApplicationServices
       Public Function GetDirectoryDrawings(directoryFullName As String, subDirsBrowse As Boolean) As List(Of FileInfo)
           Dim dir As New DirectoryInfo(directoryFullName)
           If Not dir.Exists Then
               Throw New DirectoryNotFoundException()
               Return Nothing
           End If
           Dim opt As SearchOption = SearchOption.AllDirectories
           If subDirsBrowse = False Then opt = SearchOption.TopDirectoryOnly
           Return dir.GetFiles("*dwg", opt).AsEnumerable().OrderBy(Function(x) x.FullName).ToList()
       End Function
       'change command name to suit
       <CommandMethod("wtb", CommandFlags.Session)> _
       Public Sub testDirFiles()
           Dim folder As String = "C:\Test\"
           Dim csvfile As String = "C:\Test\atable.csv"
           Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
           Dim db As Database = doc.Database
           Dim ed As Editor = doc.Editor
           Dim fd As List(Of FileInfo) = GetDirectoryDrawings(folder, False) ''     True for processing the subdirectories
           Dim collect As New StringBuilder
           If fd.Count = 0 Then Return
           Try
               Using doclock As DocumentLock = doc.LockDocument()
                   For n As Integer = 0 To fd.Count - 1
                       Dim dwgname As String = fd(n).FullName
                       Using newdb As Database = New Database(False, True)
                           ed.WriteMessage(vbLf + dwgname + vbLf)
                           Try
                               newdb.ReadDwgFile(dwgname, FileOpenMode.OpenForReadAndAllShare, False, Nothing)
                           Catch ex As Autodesk.AutoCAD.Runtime.Exception
                               If ex.ErrorStatus = ErrorStatus.DwgNeedsRecovery Then
                                   Continue For
                               End If
                           End Try
                           Using newtr As Transaction = newdb.TransactionManager.StartTransaction
                               ' Open dictionary for reading
                               Dim layoutDict As DBDictionary = DirectCast(newtr.GetObject(newdb.LayoutDictionaryId, OpenMode.ForRead), DBDictionary)
                               ' Loop through dictionary entries
                               For Each entry As DictionaryEntry In layoutDict
                                   Dim ltr As Layout = DirectCast(newtr.GetObject(DirectCast(entry.Value, ObjectId), OpenMode.ForRead), Layout)
                                   Dim btr As BlockTableRecord = DirectCast(newtr.GetObject(ltr.BlockTableRecordId, OpenMode.ForRead), BlockTableRecord)
                                   For Each id As ObjectId In btr
                                       Dim obj As DBObject = DirectCast(newtr.GetObject(id, OpenMode.ForRead), DBObject)
                                       If TypeOf obj Is Table Then
                                           Dim tbl As Table = TryCast(obj, Table)
                                           If tbl IsNot Nothing Then
                                               collect.AppendLine(String.Format("---------------------------------------"))
                                               collect.AppendLine(String.Format("Drawing name: {0}", dwgname))
                                               collect.AppendLine(String.Format("Tab: {0}", ltr.LayoutName))
                                               Dim numrows As Integer = tbl.Rows.Count
                                               Dim numcols As Integer = tbl.Columns.Count
                                               For i As Integer = 0 To numrows - 1
                                                   Dim rowline As New List(Of String)
                                                   Dim line As String = String.Empty
                                                   For j = 0 To numcols - 1
                                                       Dim cel As Cell = tbl.Cells(i, j)
                                                       rowline.Add(cel.TextString)
                                                       line = line + cel.TextString + vbTab
                                                   Next
                                                   collect.AppendLine(line.TrimEnd(vbTab))
                                               Next
                                           End If
                                       End If
                                   Next
                               Next
                               newtr.Commit()
                           End Using
                       End Using
                   Next
               End Using
               WriteTableToFile(csvfile, collect)
           Catch ex As System.Exception
               ed.WriteMessage(vbLf + ex.ToString + vbLf)
           Finally
               ed.WriteMessage(vbLf + vbTab + "--->   File saved as: {0}   <---" + vbLf, csvfile)
           End Try
       End Sub
       Public Sub WriteTableToFile(fpath As String, data As StringBuilder)
           Using fs As New FileStream(fpath, FileMode.Append, FileAccess.Write)
               Using sw As New StreamWriter(fs, Encoding.ASCII)
                   sw.WriteLine(data.ToString)
               End Using
           End Using
       End Sub
~'J'~
Share this post
Link to post
CaveMan
Good Day
Been a while since i have done some development, as always much appreciate your assistance and example code . . .
Will work through your example code, Will let you know if success.
Best Regards Richard
Keep Well
Share this post
Link to post
fixo
Thanks bro,
Let me know if some issues is appears,
~'J'~
Share this post
Link to post
greekcypriot
Hello "fixo",
Would you please answer this question:
Would DATAEXTRACT work with old Drawings prior to design of 2002 AutoCAD as well as the 2012 and later on?
Would the data extract on drawing be consistent in Column count for every drawing? or does it very from drawing to drawing?
I also try to add the VB code to a project and it can not find the names spaces mentioned in the import.
Am I doing something wrong? I have AutoCAD 2012 installed.
Thank you.
Share this post
Link to post
CaveMan
Hi There
The sample code that was given was VB.NET version 3.5
AutoCAD 2012 was upgraded to .Net 4
The Name Spaces were changed between .Net 3.5 and .Net 4
Regrets i have never upgraded the code to work on .Net 4
To be able to compile and edit the code, you can use VS 2010
Link Provided Below
http://www.microsoft.com/visualstudio/eng/downloads#d-2010-express
The setup and environment would also require a bit of understanding in Developing .Net add ons for AutoCAD. Link provided below
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
The Data below will search for all Tables then loop through all the columns then rows for the particular table, if you had 10 various table in a drawing, it will extract all the data specific to each table, no matter how different they are.
I say this under correction, but if you open a previous version of AutoCAD with tables in it and AutoDesk have not changed their table class then the data should be able to be extracted. If you look at the Properties of the object in AutoCAD as the attached image this must be Table.
I have however seen other table types in AutoCAD, Like AutoCAD Structural Detailing, but have never tried to check or extract the data from them.
Hope that the above information provides some help, If i ever get some time i will update the Data Extract function and attach a zip file with a .Net Compiled Project. Sadly i am renovating my house this side and not much time available.
Best Regards
Richard
Share this post
Link to post
