guyssss thanksss alot it finaly worked !! :D :D :D ... aiam not sure why is it .. propaly because i have to set the record on before i do any change to the shape xD ... thanks aloott you guys .. you helped me tonss to figuer alott of things out with the little codes u gave me :)
i have one question tho .... if i want the history record to be ON as defualt even before i draw anything ... how to do that ???
  • Replies 23
  • Mena__99
    13
  • Dadgad
    6
  • tzframpton
    2
  • MSasu
    1
Posted Images
I am very happy to hear that you finally got it to work. :)
I thought we had covered that one in post # 11?
In addition to having your SOLIDHIST to 1, you will notice that I have selected in the palette to RECORD, the default is NONE.
Once you do that it will all start to work for you.
As just about anything you draw in the program could be the first step of a new solid history
I believe you will need to RECORD, when you want it to.
I know it is difficult having so many different approaches and suggestions being offered
all at the same time, but if a suggestion is made, the forum members have to assume that it has been tried,
and failed, unless we hear otherwise, which leaves us no other choice than to try a different solution. :)
ya its finaly working :D .. thanks to you man for all what u did for me :)
you are pretty great :)
You're entirely welcome.
At CADtutor, we all aim to please. :)
