B-Grif Posted July 27, 2012 Posted July 27, 2012 Anyone know why my AutoCad 2009 will not let me select new layers to a specific group layer filter. It was working just fine and yesterday all of sudden it will not let me add new layers to a specific filter. Is there a button or command that maybe would have changed that function. Everything else seems to be working on the Layer Manager. Thanks for your help. Quote
JPlanera Posted July 27, 2012 Posted July 27, 2012 What type of error message, if any, are you seeing? Quote
B-Grif Posted July 27, 2012 Author Posted July 27, 2012 After I select the layer I want to add to the filter, nothing happens, no layer added, but when I try to click on anything it gives this error message "unable to modify layers while another command is Active". I can close the Layer Properties Manager and then the error message goes away. Is there anything in the "Layers States Manager" that I could have mistakenly click on that would cause this? Quote
JPlanera Posted July 27, 2012 Posted July 27, 2012 Are you drag/dropping the layer into the new filter group? I see nothing in the layer states manager that would genereate an error message like that. I tried to replicate the problem but could not get the program to act the way you describe.. Im at a loss here... Quote
khoshravan Posted July 20, 2015 Posted July 20, 2015 A question from 2012. Reading relevant post form the past to find a solution for the same problem occurred to me. Will be happy if this problem is addressed and solved. Is there any settings for layers in the option menu? Quote
RobDraw Posted July 20, 2015 Posted July 20, 2015 Please do not cross post the same question. The same issue is being discussed here: http://www.cadtutor.net/forum/showthread.php?93170-Group-Filter-name-limitation Quote
