Layout Problems
Hi Everyone,
Can Anyone Help Me, My Brain Is Locking Up! I Just Got Done With My Model Space Drawing And I'm Ready To Plot This Bad Boy, But When I Use The Layout Wizard And Answer All The Questions To It, And When You Need To Pick The Points For The Viewport, The Titleblock That I Inserted As A Block Isn't Centered Over The White Paper Layout In The Background. So I Can't Pick The Viewport Points As Asked In The Wizard. So My Drawing Ends Up On The Bottom Of The Inserted Titleblock.
What Is The Proper Method To Center The Inserted Titleblock So I Don't Have This Problem.
Explore Page Setup Options & Save Named Page Setup
If you have a mouse with the inteliwheel simply use it to zoom out to see the entire title block prior to picking the view port corners.
If you don't have the wheel on your mouse, type 'zoom, enter, E, enter, then continue. The single quote ' mark in front of the zoom allows a transparent command call to the zoom command, the E is for Extents.
HTH
