need a lisp fixed if some one would be so kind..
basically i have a lisp and it renames layers.
this will be running on mupitaple drawings through a script but at layer E-APPL i get error: bad argument type: lselsetp nil
this in not even halfway through my layers.
any ideas ?
;;function to rename a layer.
;;if old layer exists, and new layer doesn't exist, the old layer is simply renamed.
;;if old layer exists, and new layer is already there, it takes everything on old layer and puts them on new layer.
;;if old layer doesn't exist, it does nothing.
(defun renlay (ol nl / ss i ent )
 (cond ((and (tblsearch "layer" ol) (not (tblsearch "layer" nl)))
 (command "._rename" "la" ol nl)
((and (tblsearch "layer" ol)(tblsearch "layer" nl))
  (setq ss (ssget "x" (list (cons 8 ol))))
  (setq i -1)
   (repeat (sslength ss)
      (setq ent (entget (ssname ss (setq i (1+ i))))
     ent (subst (cons 8 nl) (cons 8 (cdr (assoc 8 ent))) ent)
      (entmod ent)
((not (tblsearch "layer" ol))
  (prompt (strcat "\nLayer " ol " not found. "))
;;example
(defun c:layre ()
  ( renlay "21" "remove" )
  ( renlay "32" "A-RNAM" )
  ( renlay "33" "A-RNUM" )
  ( renlay "37" "A-ANNO" )
  ( renlay "59" "A-RNAM" )
  ( renlay "65" "L-WALK" )
  ( renlay "72" "L-WALK" )
  ( renlay "140" "L-PLANT-TREE" )
  ( renlay "228" "remove" )
  ( renlay "230" "remove" )
  ( renlay "250" "S-STEEL" )
  ( renlay "420" "L-WALK" )
  ( renlay "450" "A-ROOF" )
  ( renlay "461" "A-WIND" )
  ( renlay "465" "A-DOOR" )
  ( renlay "470" "A-WIND" )
  ( renlay "480" "A-DOOR" )
  ( renlay "600" "F-FURN-FIXT" )
  ( renlay "610" "F-FURN-FREE" )
  ( renlay "737" "P-PLUM" )
  ( renlay "850" "M-AIRCON" )
  ( renlay "920" "remove" )
  ( renlay "$AUDIT-BAD-LAYER" "remove" )
  ( renlay "000HATCH" "remove" )
  ( renlay "021_A1BASE" "remove" )
  ( renlay "021-A1-SHEET" "remove" )
  ( renlay "021-SHEET" "remove" )
  ( renlay "030-DIMENSIONS" "A-ANNO-DIMS" )
  ( renlay "032_NAME" "A-RNAM" )
  ( renlay "032-RNAME" "A-RNAM" )
  ( renlay "032ROOMNAMES" "A-RNAM" )
  ( renlay "032-ROOMNAMES" "A-RNAM" )
  ( renlay "033_ROOM-NUMBERS" "A-RNUM" )
  ( renlay "033-RNUMB" "A-RNUM" )
  ( renlay "034_FLOOR-FINISHES" "A-FLOR-PAT" )
  ( renlay "034-FLOOR_FIN" "A-FLOR-PAT" )
  ( renlay "034-FLOOR-FINISHES" "A-FLOOR-PAT" )
  ( renlay "035_DETAIL-REF-NO" "remove" )
  ( renlay "036_SECTION-REF-NO" "remove" )
  ( renlay "037_TEXT" "A-ANNO-TXT" )
  ( renlay "037_TEXT-PARTITION" "A-ANNO-TXT" )
  ( renlay "037-ARCH_TEXT" "A-RNUM" )
  ( renlay "037-ELC-TEXT" "remove" )
  ( renlay "037GENERALTEXT" "A-ANNO-TXT" )
  ( renlay "037-NOTES" "remove" )
  ( renlay "037-REFERENCE" "LDADEL" )
  ( renlay "037-TEXT" "A-ANNO-TXT" )
  ( renlay "040BUILDINGGRID" "A-GRID" )
  ( renlay "062_HATCH-BRICK" "A-WALL" )
  ( renlay "062_HATCH-MASONRY" "A-WALL" )
  ( renlay "072_BOUNDARY" "L-SITE" )
  ( renlay "072_FENCE" "L-SITE-FENC" )
  ( renlay "072_PARKING" "L-WALK" )
  ( renlay "072_PAVING" "L-WALK" )
  ( renlay "072_RETAINING-WALL" "A-WALL" )
  ( renlay "072_SITE" "L-SITE" )
  ( renlay "072_SITE-FEATURES" "L-SITE" )
  ( renlay "072-190" "remove" )
  ( renlay "072-SITE" "L-SITE" )
  ( renlay "140-VEGETATION" "L-PLANT-PLAN" )
  ( renlay "220_CONCRETE" "S-CON" )
  ( renlay "230_MASONRY-WALLS" "A-WALL" )
  ( renlay "230_WALLS_MASONRY" "A-WALL" )
  ( renlay "230_WALLS_STUDS" "A-WALL-STUD" )
  ( renlay "230-WALL" "A-WALL" )
  ( renlay "231_EX-WALLS" "A-WALL" )
  ( renlay "231-EXISTINGWALLS" "A-WALL" )
  ( renlay "250_COL" "S-COL" )
  ( renlay "250_STRUCTURAL-STEEL" "S-STEEL" )
  ( renlay "260_METALWORK" "S-STEEL" )
  ( renlay "280NEWGLAZING" "A-WIND" )
  ( renlay "290_STAIRS" "A-STAIR" )
  ( renlay "420_PAVING" "L-WALK" )
  ( renlay "420-PAVING" "L-WALK" )
  ( renlay "444_PARTITION" "A-WALL" )
  ( renlay "444_STUD" "A-WAL" )
  ( renlay "444NEWPARTITON" "A-WALL" )
  ( renlay "445-EXIST_PART" "A-WALL" )
  ( renlay "447_SCREENS" "remove" )
  ( renlay "450_DOWNPIPIES" "remove" )
  ( renlay "450_ROOFING" "A-ROOF" )
  ( renlay "450-ROOF" "A-ROOF" )
  ( renlay "459_SUSPEMDED-CEILING" "remove" )
  ( renlay "459-CEILING" "remove" )
  ( renlay "459CEILINGEXISITNGLIGHT" "remove" )
  ( renlay "459-NEW" "remove" )
  ( renlay "461_WINDOWS" "A-WIND" )
  ( renlay "461-EXTERNAL" "A-WIND" )
  ( renlay "461-OBSERV" "A-WIND" )
  ( renlay "461-WIND" "A-WIND" )
  ( renlay "462_EX-WINDOWS" "A-WIND" )
  ( renlay "465_DOORS" "A-DOOR" )
  ( renlay "465-444" "A-DOOR" )
  ( renlay "465-DOORS" "A-DOOR" )
  ( renlay "465NEWDOORS" "A-DOOR" )
  ( renlay "466_EX-DOORS" "A-DOOR" )
  ( renlay "466-444" "A-DOOR" )
  ( renlay "467_WINDOWS-REMOVED" "remove" )
  ( renlay "552TILES" "remove" )
  ( renlay "553-VINYL" "A-FLOR-PAT" )
  ( renlay "600_FIXED-FURNITURE" "I-FURN-FIXT" )
  ( renlay "600_FURN_FIXED" "I-FURN-FIXT" )
  ( renlay "600-FFURN" "A-FUN-FREE" )
  ( renlay "600-FIXED-FURN" "F-FURN-FIXT" )
  ( renlay "600FIXEDFURNITURE" "F-FURN" )
  ( renlay "600-FURNITURE_FIXED" "F-FURN-FIXT" )
  ( renlay "601_EX-FIXED-FURNITURE" "I-FURN-FIXT" )
  ( renlay "610-FURNITURE-LOOSE" "F-FURN-FREE" )
  ( renlay "610-LOOSE_FURN" "F-FURN-FREE" )
  ( renlay "610LOOSEFURNITURE" "F-FURN-FREE" )
  ( renlay "611_FURN-NIC" "remove" )
  ( renlay "650_NEW-PLUMBING" "P-PLUM" )
  ( renlay "651_EX-PLUMBING" "P-FIXT" )
  ( renlay "700-HYD" "P-PLUM" )
  ( renlay "700-PLUMBING" "P-PLUM" )
  ( renlay "737_PLUMB" "P-PLUM" )
  ( renlay "737_PLUMBING" "P-FIXT" )
  ( renlay "737-PLUMBING-FIX" "P-PLUM" )
  ( renlay "783-FIRE-EX" "remove" )
  ( renlay "790-COMP" "remove" )
  ( renlay "850_MECH" "M-AIRCON" )
  ( renlay "850-MECHANICAL" "A-MEC" )
  ( renlay "920_ROADS" "remove" )
  ( renlay "922-ROAD" "remove" )
  ( renlay "930-SEMI-ENCL-SPACES" "remove" )
  ( renlay "A_Col" "S-COL" )
  ( renlay "A_DOOR" "A-DOOR" )
  ( renlay "A_Door" "A-DOOR" )
  ( renlay "A_Doors" "A-DOOR" )
  ( renlay "A_Furn" "I-FURN" )
  ( renlay "A_Paving" "L-WALK" )
  ( renlay "A_Roof" "A-ROOF" )
  ( renlay "A_Sani" "P-PLUM" )
  ( renlay "A_Text" "A-ANNO-TEXT" )
  ( renlay "A_Walls" "A-WALL" )
  ( renlay "A_WIND" "A-WIND" )
  ( renlay "A_Window" "A-WIND" )
  ( renlay "A1-BORDER" "remove" )
  ( renlay "A1-NPOINT" "remove" )
  ( renlay "A1-SHEET" "remove" )
  ( renlay "A1-TITLE" "remove" )
  ( renlay "A-Anno-Scrn" "remove" )
  ( renlay "A-Back-Colr" "remove" )
  ( renlay "A-BASE" "A-WALL" )
  ( renlay "A-BEAM" "S-COL" )
  ( renlay "A-CE-GE" "remove" )
  ( renlay "A-CEIL" "remove" )
  ( renlay "A-CE-WA" "remove" )
  ( renlay "ACOL" "S-COL" )
  ( renlay "A-COL" "S-COL" )
  ( renlay "A-COL-CONC" "S-COL-CONC" )
  ( renlay "A-COL-STEEL" "S-COL-STEEL" )
  ( renlay "A-CONC" "S-COL-CONC" )
  ( renlay "A-DE-GE" "remove" )
  ( renlay "A-DE-HA" "remove" )
  ( renlay "ADOOR" "A-DOOR" )
  ( renlay "A-EL-GE" "remove" )
  ( renlay "A-EL-GE1" "remove" )
  ( renlay "A-EL-GE2" "remove" )
  ( renlay "A-EL-HA" "remove" )
  ( renlay "AFIRE" "A-FIRE" )
  ( renlay "AFIRE" "F-FIRE" )
  ( renlay "AFIXT" "I-FURN-FIXT" )
  ( renlay "AFIXT" "A-FIXT" )
  ( renlay "A-FL-AREABDRY" "remove" )
  ( renlay "A-FL-AREADEPT" "remove" )
  ( renlay "A-FL-AREARM" "remove" )
  ( renlay "A-FL-DI" "remove" )
  ( renlay "A-FL-DI1" "remove" )
  ( renlay "A-FL-DO" "remove" )
  ( renlay "A-FL-GE" "remove" )
  ( renlay "A-FL-GRID" "remove" )
  ( renlay "A-FL-HA" "remove" )
  ( renlay "AFLOOR" "A-FLOOR" )
  ( renlay "A-FLOOR-FIN" "A-FLOOR" )
  ( renlay "A-FLOOR-FINISH" "A-FLOOR" )
  ( renlay "AFLOR" "A-FLOOR" )
  ( renlay "A-FL-ST" "remove" )
  ( renlay "A-FL-TE" "remove" )
  ( renlay "A-FL-TE1" "remove" )
  ( renlay "A-FL-TE2" "remove" )
  ( renlay "A-FL-WI" "remove" )
  ( renlay "A-FURN" "I-FURN-FIXT" )
  ( renlay "A-FURN-FIXED" "I-FURN-FIXT" )
  ( renlay "A-FURN-LOOSE" "I-FURN-FREE" )
  ( renlay "A-GE-AREABA" "remove" )
  ( renlay "A-GE-GR" "remove" )
  ( renlay "A-GE-HA" "remove" )
  ( renlay "A-GE-TE" "remove" )
  ( renlay "A-GE-TE1" "remove" )
  ( renlay "A-GE-TE2" "remove" )
  ( renlay "AGLAS" "A-WIND" )
  ( renlay "AGLAS" "A-QIND" )
  ( renlay "AGRID" "A-GRID" )
  ( renlay "A-HANDRAIL" "A-FLOR-HRAL" )
  ( renlay "A-METALWK" "remove" )
  ( renlay "annot - demolition" "remove" )
  ( renlay "annot proposed" "remove" )
  ( renlay "A-PART" "A-WALL-MOVE" )
  ( renlay "APATH" "A-PATH" )
  ( renlay "A-PLUMB" "P-PLUM" )
  ( renlay "APPLIANCE" "remove" )
  ( renlay "A-RAMP" "A-FLOR-LEVL" )
  ( renlay "A-RDOOR" "A-DOOR" )
  ( renlay "A-RM-AREA" "A-AREA" )
  ( renlay "A-RMNAM" "A-RNAM" )
  ( renlay "ARNAM" "A-RNAM" )
  ( renlay "ARNUM" "A-RNUM" )
  ( renlay "A-RO-EA" "remove" )
  ( renlay "A-RO-GE" "remove" )
  ( renlay "A-RO-HA" "remove" )
  ( renlay "AROOF" "A-ROOF" )
  ( renlay "A-ROOM NUMBERS" "remove" )
  ( renlay "A-ROOM-LEGEND" "remove" )
  ( renlay "A-SANIT" "P-FIXT" )
  ( renlay "A-SCALE 100" "remove" )
  ( renlay "As-Constructed" "remove" )
  ( renlay "A-SD-MASSSPCE" "remove" )
  ( renlay "ASHADE" "remove" )
  ( renlay "A-STAIR-CONC" "A-STAIR" )
  ( renlay "A-ST-CO" "remove" )
  ( renlay "A-ST-HA" "remove" )
  ( renlay "ATEXT" "A-ANNO-TEXT" )
  ( renlay "A-TEXT" "A-ANNO-TEXT" )
  ( renlay "A-TXT" "A-ANNO-TXT" )
  ( renlay "A-TXT" "A-ANNO-TEXT" )
  ( renlay "AUCA" "A-UCA" )
  ( renlay "A-WA-GE" "remove" )
  ( renlay "A-WA-HA" "remove" )
  ( renlay "AWALL" "A-WALL" )
  ( renlay "centrline" "remove" )
  ( renlay "columns" "S-COL" )
  ( renlay "Dimensions" "A-ANNO-DIM" )
  ( renlay "DOOR" "A-DOOR" )
  ( renlay "door schedule" "remove" )
  ( renlay "doors" "A-DOOR" )
  ( renlay "E-APPL" "remove" )
  ( renlay "E-CbltHatch" "remove" )
  ( renlay "E-DISTRUBUTION" "E-POWER-SWBD" )
  ( renlay "E-ELECT" "E-POWER" )
  ( renlay "E-Halo-High" "remove" )
  ( renlay "E-Halo-Subd" "remove" )
  ( renlay "elec" "E-ELEC" )
  ( renlay "E-Lite-Detail" "remove" )
  ( renlay "E-Lite-Diagonal" "remove" )
  ( renlay "Extg" "remove" )
  ( renlay "FENCE" "L-SITE-FENC" )
  ( renlay "FIREEQUIP" "remove" )
  ( renlay "FIXTURES" "I-FURN-FIXT" )
  ( renlay "Fixtures" "F-FURN-FIXT" )
  ( renlay "FRAME" "A-ANNO" )
  ( renlay "FRAME" "remove" )
  ( renlay "FURN" "I-FURN" )
  ( renlay "FURNITURE" "I-FURN-FIXT" )
  ( renlay "furniture" "A-FURN-FREE" )
  ( renlay "G-Anno-Nplt" "remove" )
  ( renlay "G-Bgrd-Std-Scrn" "remove" )
  ( renlay "GRID" "A-GRID" )
  ( renlay "HANDRAIL" "A-FLOR-HRAL" )
  ( renlay "HATCH" "A-HATCH" )
  ( renlay "hatch - new beams" "remove" )
  ( renlay "hatch infill" "remove" )
  ( renlay "Hidden" "remove" )
  ( renlay "HYDRAULICS" "I-FURN-FIXT" )
  ( renlay "LANDSCAPE" "L-SITE" )
  ( renlay "Layer1" "remove" )
  ( renlay "MASONRY" "A-WALL" )
  ( renlay "M-DuctHatch" "remove" )
  ( renlay "M-Halo-High" "remove" )
  ( renlay "M-Halo-Subd" "remove" )
  ( renlay "NEW" "remove" )
  ( renlay "NORTH" "remove" )
  ( renlay "PATH" "L-WALK" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$037_GenTxt 0100" "A-ANNO-TEXT" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$220_CONC" "S-COL-CONC" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$220_Existing Conc" "S-COL-CONC" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$231_Column Conc" "S-COL-CONC" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$231_Existing Fixtures" "A-FIXT" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$231_Existing Walls" "A-WALL" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$260_Balustrade" "A-FLOR-HRAL" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$465_DOOR" "A-DOOR" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$465_Door Matt" "A-DOOR" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$730_Sump" "remove" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$737_Fixture Sanitary" "P-PLUM" )
  ( renlay "PCCD200P5$0$A_Base Plan$0$741_Fire HoseReel" "F-FIRE" )
  ( renlay "PCCD200P5$0$A_Furniture Plan$0$600_Fixed Furniture" "I-FURN-FIXT" )
  ( renlay "PCCD200P5$0$A_Furniture Plan$0$610_Loose Furniture B" "I-FURN-FREE" )
  ( renlay "PCCD200P5$0$A_Furniture Plan$0$A Joinery" "I-FURN" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$032_Room Names" "A-RNAM" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$231_Existing Fixtures" "A-DOOR" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$440_Xrefs" "remove" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$444_New Partitions" "A-WALL-PATT" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$461_Window" "A-WIND" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$465_DOOR" "A-DOOR" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$600_Fixed Furniture" "I-FURN-FIXT" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$737_Fixture Sanitary" "P-PLUM" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$A Column Conc" "S-COL-CONC" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$A Furniture Equipment" "I-FURN" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$A Joinery" "A-WALL" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$A Wall Int" "A-WALL" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$A Wall Int Glazed" "A-WALL" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$ST_Door" "A-DOOR" )
  ( renlay "PCCD200P5$0$A_Partition Plan$0$ST_Fixture Sanitary Hardware" "P-PLUM" )
  ( renlay "PCCD200P5$0$I_PL-GA_01_0100$0$032_Room Names" "A-RNAM" )
  ( renlay "PERGOLA" "L-SITE-DECK" )
  ( renlay "PLUMB" "P-PLUM" )
  ( renlay "PLUMBING" "P-PLUM" )
  ( renlay "REVDATE" "remove" )
  ( renlay "RNUM" "A-RNUM" )
  ( renlay "ROADWAY" "remove" )
  ( renlay "STEEL" "A-COL" )
  ( renlay "STUD" "A-WALL" )
  ( renlay "tblock" "remove" )
  ( renlay "TERRAZZO" "A-WALL" )
  ( renlay "TEXT" "A-ANNO" )
  ( renlay "Text - c'work" "remove" )
  ( renlay "title block" "remove" )
  ( renlay "TTLB" "remove" )
  ( renlay "TXT25" "A-RNAM" )
  ( renlay "TXT35" "A-RNAM" )
  ( renlay "VERANDAH" "L-SITE-DECK" )
  ( renlay "WALL" "A-WALL" )
  ( renlay "walls" "A-WALL" )
  ( renlay "WINDOW" "A-WIND" )
  ( renlay "windows" "A-WIND" )
  ( renlay "X-Anno-Conn" "remove" )
Please check that in your list you used the same new name for more than one remaning case; at the time the second case is reached, there is already a layer with that name.
(renlay "21" [color=red]"remove"[/color])
(renlay "228" [color=red]"remove"[/color])
(renlay "230" [color=red]"remove"[/color])
the problem is i may need to put different layers to remove as laiter in the script i will be removing any layers on the layer remove??
Then try something like:
(renlay "21" "remove1")
(renlay "228" "remove2")
(renlay "230" "remove3")
if thats the only way around it, can my lisp to delete objects on remove layer be changed to delete objects that have remove in there layer name so i dont have one a lisp for each layer called remove, remove 1 ect.
(defun C:rmly (/ SSetLayer)
  (setq SSetLayer (ssget "_X" '((8 . "remove"))))
  (if SSetLayer
 (command "._Erase" SSetLayer "")
The error in the code from first post occurs when it try to merge the content of layers with the same projected new name; the line below will return nil if processed layer (old name) is empty.
Thus the error when try to process the presumed selection set - try instead:
[color=red](if [/color](setq ss (ssget "x" (list (cons 8 ol))))
[color=red] (progn[/color]
 (setq i -1)
        ent (subst (cons 8 nl) [s][color=red](cons 8 (cdr [/color][/s](assoc 8 ent)[s][color=red]))[/color][/s] ent)
  (entmod ent)
[color=red] )[/color]
[color=red])[/color]
What should happen with processed layer in this case?
Mircea yet again you have saved my bacon.. i could kiss you.. thanks so much.. :D
