How to change .brd format to CAD compatible format.
Hey guys/girls I made a stand up paddle board in a program called ACU shaper which is a .brd extension, I know a guy with a hotwire to cut my foam but he needs it in CAD format. If anyone has any suggestions I will try them all until we find the solution, thanks. :)
Please check what other file formats is the said ACU shaper application able to export - it will be useful if supports DXF.
Did you mean AKU Shaper?
Also find out which CAD format is needed.
You will need to download BoardCAD to import your .brd and export as STP, DXF or STL.
Yeah I meant AKU shaper.
he wanted .dxf
So I got BoardCAD so much for that worked a charm... Hopefully this guy thinks so as well.
  • 1 year later...
hello, i also am trying to do something similar to this. i'm making (or about to) eps cored timber skinned surfboards - no fiberglass, 4-6mm timber skins and sealed. but i need to be able to take an aku shaper BRD file and turn this into a basic dfx file. the dfx file will only have the plan shape of the board - outside circumference and the basic bottom curve. the eps blank will then have the stringer glued in and a 3mm band glued around the outside. it will then be shaped on the aku shaper machine. if anyone is able or interested in doing this for me it would be much appreciated. this is not going to be a commercial enterprise - purely for myself family and friends. i am prepared to pay if necessary. thanks - karuhi
