bigmaz Posted August 2, 2012 Posted August 2, 2012 Hi guys We are using SSM, and it is getting quite annoying right clicking each sheet to input the info for each sheet, as not each sheet has the same info. Is there not a way to import the data from a spreadsheet, so you can fill out all the data in a spreadsheet how you want it, then import it into the SSM? Quote
rkmcswain Posted August 2, 2012 Posted August 2, 2012 This tool here works directly on the .DST file, so AutoCAD is not required to use it. It will allow you to update multiple sheets at once. http://www.jtbworld.com/SSMPropEditor.htm Quote
BIGAL Posted August 3, 2012 Posted August 3, 2012 If you use the sheet set to create all your sheets with say a default title block then its easy to run a seperate program to populate all the title blocks with what ever you want. Here is an example of updating layouts http://www.cadtutor.net/forum/showthread.php?71417-Auto-Numbering-Layout-Tabs-from-a-Table-of-Contents I am pretty sure there are posts for excel to layout tabs did you search? Quote
