Hello all,
I have this issue where I have stone right below some framing and other objects. I use a hatch to fill in the square of stone. When I use the hatch, I send it to the back of the drawing order, but it is right below a bunch of my dimensions. These dimensions become hard to see. I could have sworn that I once saw my hatches leave some extra room around the dimensions. Is there a way to make them easier to see? I guess the ugly solution I have right now is to put small boxes around anything within the hatch to leave some room.
Thanks,
Either through properties or DimStyles set Text Fill Color to Background.
You can also select the dimensions when selecting the object with the island mode set to outer, or when selecting the point.
I'm unable to "publish" my layouts to a pdf when setting my rotated dimensions text fill colour "background", I get the error message: "Your request could not be completed due to an unexpected problem. Turn off background plotting and try to plot again." Is this common? Is there a work-around?
I didn't, it works now. Thank you.
Exactly what is background plotting? and what happens when I uncheck it?
