e.mounir Posted November 4, 2008 Posted November 4, 2008 Hi every one We have a big project contain 500 Sheet arch. And every sheet has 5 base file as xrefs All xrefs is full path we need convert the xrefs to relative path because we have partners in anther Country used the same folder structure Any one have any resolution for this case We don’t need make detached for all xrefs and make it attached the xrefs form the bingeing Quote
lpseifert Posted November 4, 2008 Posted November 4, 2008 Try using Reference Manager to change from full to relative. Quote
e.mounir Posted November 4, 2008 Author Posted November 4, 2008 I tray it but I found edit save path only I don’t know how can I make it relative Quote
rkmcswain Posted November 4, 2008 Posted November 4, 2008 Edit saved path is what you do. You edit the saved path from full to a relative path. If the full path to the xref is "X:\Projects\888\1210\dwg\base\myxref.dwg" and the parent drawing lives in "X:\Projects\888\1210\dwg", then set the path to "base\myxref.dwg" Quote
e.mounir Posted November 4, 2008 Author Posted November 4, 2008 it is working Thanks for your effort Quote
