anishtain4 Posted August 7, 2012 Posted August 7, 2012 I need a lisp to use DT command in a way that when the user press the enter no new line get started and command ends, how should I do it? absolutely no idea Quote
anishtain4 Posted August 7, 2012 Author Posted August 7, 2012 never mind, got it. I should make the user press enter twice Quote
CALCAD Posted August 8, 2012 Posted August 8, 2012 In case you may still be interested, here is a program to do what you asked for. (defun Text (pt hgt str) (entmakex (list (cons 0 "TEXT") (cons 10 pt) (cons 11 pt) (cons 40 hgt) (cons 72 0) ; lower left justified (cons 1 str))) ) (defun c:dtxx (/ *ERROR* osave c txtstr txtsz) (defun *ERROR* (msg) (setvar "OSMODE" osave) (princ) ) (setq osave (getvar "OSMODE")) (setvar "OSMODE" 0) (setq txtsz (getvar "TEXTSIZE")) (setq c (getpoint "\nSelect location: ")) (initget 129) (setq txtstr (getstring T "\nText: ")) (terpri) (terpri) (Text c txtsz txtstr) (setvar "OSMODE" osave) (princ) ) The rotation angle is the default (zero) and the current text size is used. You could, of course, add code to get these values from the user. Quote
