I have a drawing that I unioned some of the object (a 3D pipe network), and now I want them individually again.
Instead of doing the slice command at every point, is there a way to explode them or un-union them all at once?
Thanks!
If that is a single body, then SLICE is the only option to my knowledge. If those parts form a single entity, but are not in contact, you have the SOLIDEDIT command with Separate Solids option.
There is also a Solid History feature, but I never used it so not sure if this may be helpful in your case.
